What 4th gen suspension parts swap onto the TTA (GTA) ?! ---
Old Apr 23, 2009 | 04:14 AM
alwayscode390's Avatar
I thought I read somewhere that some of the 4th gen suspension parts swap onto the TTA's (GTA suspension for the most part besides the front struts).
I have an adj panhard rod, lower control arms, lca relocation brackets, and a bmr adjustable torque arm (for a 6 speed if that matters) on my 96'z28 that I am about to sell.
The springs and shocks are different right? ( I have coilovers, a strut brace, and bilsteins too)
If I can swap off the parts I would love to ... thanks for the help ---
Old Apr 23, 2009 | 04:21 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: What 4th gen suspension parts swap onto the TTA (GTA) ?! ---
they have nothing stock that you can swap to your car that would benifit you over what you already have on the car.
the only parts that swap are the rear springs and sway bar, the rear axle, the rear shocks, rear control arms and panhard bar. Nothing in the front will swap over.
Old Apr 23, 2009 | 05:22 PM
Thank you very much ---
Old Apr 23, 2009 | 06:23 PM
Stephen's Avatar
Car: 87 GTA
You can swap all of that stuff on. I'm not certain about the torque arm though. The tranny mount end might be different, but I doubt it. If so, just use the TTA torque arm.
That way you can save your adjustable stuff & sell the 96 with stock style parts. Older, but the same.
Is your LCARBs bolt on? If so, take them off the 96 & put them on the TTA, or sell them.
Old Apr 23, 2009 | 08:49 PM
Yep, they are bolt ons ... I appreciate the help !!!
I also have SLP full size bolt on subframe connectors on the 96'. Will those swap too?! ---
Old Apr 23, 2009 | 09:10 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Yes on the rear control arms, relocation brakets, springs, shocks, panhard, panhard brace, and sway bar. Only thing is the springs...depending on their stiffness may change ride height/feel a tad. But I doubt it.
Maybe on the torque arm....but pretty sure you can.
Def. no on the sub frame connectors and anything up front.
J.
Old Apr 23, 2009 | 11:03 PM
Pocket's Avatar
Car: 91 Trans Am
The TA will swap, but is heavier than the 3rd gen version as it has the mount for the multi-section driveshaft (V6 cars) and just as flimsy
Frozer!!!
Jan 19, 2024 04:55 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
lee01
Apr 9, 2016 01:56 PM
redmaroz
Aug 16, 2015 11:40 PM
1nastygta
Aug 8, 2015 07:38 PM
