Will gears from a 89 firebird fit in a 86 camaro?
Old Apr 26, 2009 | 02:29 PM
dranate's Avatar
Car: 1986 camaro, 1992 and 1994 saturn
Engine: 305 wanting a 350
Help I need to know asap if this will work I have in my camaro 2.73 open and the firebird has 3.73 limited slip will it fit if I just swap out the gears. Please Let me know asap thank you
Old Apr 26, 2009 | 02:33 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Will gears from a 89 firebird fit in a 86 camaro?
no, the gears will not just swap over.
They use a different carrier. You could probably swap the entire carrier, but depending on the splines of the axles, you may have to swap them too.
why not just take the entire rear and swap the whole thing?
Old Apr 26, 2009 | 02:34 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Since your 86 is an open diff and you want to put the 3.73 with the posi then yes, they will fit. The gears themselves won't swap over but the entire carrier can be swapped over.
The 89 should still have 26 spline axles like your 86
Old Apr 26, 2009 | 02:39 PM
dranate's Avatar
can i just swap out the 2 different carriers or no?
Old Apr 26, 2009 | 03:26 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Again, better to swap the entire rear axle assembly, housing and all. Easier, too.
Old Apr 26, 2009 | 09:15 PM
AlkyIROC's Avatar
Car: 87 IROC L98
You can swap out the gears with the posi carrier. It depends how well you can set up the gears in the older diff. As mentioned above, it's easier to just swap the complete diff.
Old Apr 27, 2009 | 08:19 AM
dranate's Avatar
I cant get my rear end off that why I am going to just swap out the carrier. But do you think that a dirt bike for a whole rear end is a good deal?
Old Apr 27, 2009 | 08:23 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by dranate
I cant get my rear end off....
May I ask why?
JamesC
Old Apr 27, 2009 | 08:33 AM
dranate's Avatar
I am trading a guy tonight for it my dirtbikes a 1980`s something suzuki rm80
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
hectre13
Aug 26, 2015 08:17 AM
InfinityShade
Aug 22, 2015 08:00 PM
Vintageracer
Aug 11, 2015 08:13 PM
armybyrd
Aug 10, 2015 09:23 PM
