Spohn Tie Rod Adjusters wont go on
Old May 2, 2009 | 05:23 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Transmission: T5 non-W/C
Axle/Gears: 3.27 Open
Ok so i got the stock tie rod adjusters off but the new Spohn Tie Rod Adjusters thread on for about 3/4 on both inner and outer rod but get stuck at about that point. Its just progressively harder to turn util that point and then i get too weak... Did anyone else have this problem???
I lubed the threads and wire brushed them.
Old May 2, 2009 | 05:41 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Spohn Tie Rod Adjusters wont go on
New parts being assemblied on old parts = PROBLEMS Just my opinion..
Old May 2, 2009 | 06:53 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
The threads on the tie rods are messed up, rusted, ect. You need to get a die to clean up the threads. I forget the thread size, 5/8 fine maybe?
Other than that, you can buy new tie rod end.
Old Oct 22, 2012 | 03:18 PM
rwstegne's Avatar
Car: 1989 Iroc Z 5.7L
Engine: 5.7L
Axle/Gears: built 4.10s
Did you ever get your threads fixed? I now have the same problem. The alignment show destroyed my stock adjusters with a pipe and could not get the drive side free, so I purchased the spohn adjusters but need to clean up the threads. A friend has a 5/8 by 18 die to clean up the one side of the tie rod, but what about the inner?
Old Oct 22, 2012 | 04:27 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Same thread but a left handed one.
RBob.
Old Oct 22, 2012 | 05:16 PM
rsmith085's Avatar
Car: '88 Camaro
Engine: L03 TBI
Transmission: WC T-5
Axle/Gears: 7.625 10 bolt stock 3.08's
I have the UMI adjusters, used new tie rods and no problems. New tie rods aren't that much money and worth it on a car thats 20+ years old. For what you'd pay for a 5/8-18 left hand die you could probably buy new ones anyway. But yeah when I took mine in to Tire Kingdom for an alignment they wrecked my stock ones with channel locks and then a pipe wrench. The tech couldn't understand why they wouldn't turn, but when you collapse then stock adjuster in on it self it just grips the tie rod tighter, freakin brilliant guy lol. When I got the car home I coated them in pb blaster and used a tie rod tool and like magic they turned freely but they were mangled up so bad I was scared they were gonna snap in two.
Old Oct 22, 2012 | 06:29 PM
rwstegne's Avatar
Engine: 5.7L
So, I am not the only one. I noticed the cost of the dies, so I was thinking the same thing since the prices at rockauto.com are pretty reasonable. Which tie rod brand did you go with?
Old Oct 22, 2012 | 07:21 PM
rsmith085's Avatar
Car: '88 Camaro
Engine: L03 TBI
Yeah thats an oddball thread even if it was a common one like 1/2-13 or something the left hand thread is gonna command a premium. They were the white box special close out's I paid like 8 bucks a piece lol even so I've had them on for 10 months now with no problems and my car is my daily driver.... If you want quality ones definitely go with Moog, they pretty much are the only quality after market manufacturer of suspension parts but the price reflects that. All the cheaper ones are gonna have a plastic cup that the ball part of the stud goes into whereas the Moog has a metal cup. Also I have only good things to say about RockAuto I've ordered a bunch of parts from them and use them anytime I don't need something right now. You can also get really good deals when they have something on closeout, I got Moog struts for 20 bucks a piece when they go for 60 at the local parts store.
Old Oct 22, 2012 | 07:58 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
I have a set of Spohn adjusters on the bench on my winter to-do list. Good heads up here. I'll have to watch out for this problem.
Old Oct 23, 2012 | 01:19 AM
actarnoff's Avatar
Car: 1991 RS/B4C clone
Engine: 355 TPI
Transmission: Probuilt Street/Strip 700r4
Axle/Gears: 7.625 axle with 3.23 gears/TrueTrac
I had this problem with the Coleman adjusters I bought, which are the same type. Honestly, I just lost patience and he-maned them on. The shop had no problem adjusting them.
Old Oct 23, 2012 | 11:06 AM
rwstegne's Avatar
Engine: 5.7L
Just cleaned up one of the outer tie rod no problem thanks to a friend with a 5/8" by 18 die. All of my tie rods seem solid so I am going to use a die on the outers, then soak and clean with a wire brush the inners. Hopefully, that works. Hate to through away more good parts since my tire shop messed up my adjusters.
Attached Thumbnails Spohn Tie Rod Adjusters wont go on-dsc08551.jpg   Spohn Tie Rod Adjusters wont go on-dsc08552.jpg
Old Dec 3, 2012 | 08:39 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Yes a 5/8 x 18 NF thread die/re-threader works just fine. The inner tie rod end is left hand threads so make sure you're using the correct left hand nuts in the Spohn kit. The tie rod connector has a notch to indicate the left hand thread side.
Hotrodboba400
Dec 10, 2019 07:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
