would it be worth it???? need quick answer
Old May 13, 2009 | 03:34 PM
Outlaw28's Avatar
Car: 1986 camaro z28
Engine: 350sbc
Transmission: TKO 600
Axle/Gears: stock axle with 4.11's
not sure where to post this...i have 84 z28 frame bent found a rs v6 camaro guy parting out body and frame in perfect shape...would it be worth it to convert everything over to the v6 one? motor trans...interior...rear end...driveshaft...suspension...my spoiler and change all the emblems to z28...or would it be better to take what i need from it and just get my frame fix and get all the body work fixed...???? need quick answer on this thx....mod if you want to move this into section you think is better plz do
Old May 13, 2009 | 03:45 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: would it be worth it???? need quick answer
depends on the amount of damage done to car....are you talking just front sub-frame damaged??
Old May 13, 2009 | 03:50 PM
Outlaw28's Avatar
Engine: 350sbc
on my car the frame is bent front pass wheel pushed back 2 inch and in about inch still drives just pulls to right a bit...and it has some dmg to pass quater panel...this is my current car one im going to look at has no body dmg...its a v6 though and paint is good and rims and tires good...just wanting to know if it be worth it or not
Old May 13, 2009 | 04:25 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
well, if your's is damaged and V6 car is not, and you have the mechanical know-how, I'd get the V6 car and swap all your car's stuff into the V6 shell
Old May 13, 2009 | 06:18 PM
Outlaw28's Avatar
Engine: 350sbc
yeah i got the know how...well ima go take a look tomarrow...if i dont get it i might just get a few parts off of it...anyways thx for advice
Old May 15, 2009 | 08:00 PM
Outlaw28's Avatar
Engine: 350sbc
ok well the guy lied about the car...he said it had no body dmg or scratches in paint...clear coat was peeling off back bumper had a huge dent in pass front bumper and the hole front end of car has been replaced and wasnt even painted it was primer grey and was being hidden under a nose bra...guy wasnt even there when i showed up even though he was oppose to be finally he calls me back and says he will be there in two hours...i said forget it not interested and hoped back in truck and drove 2 hours back home...so it was like a total of 4 hours of driving there and back...big waste of my time...bummer too i was excited about it...
J-money
Jan 4, 2019 09:45 AM
Twin_Turbo
Mar 14, 2016 10:10 PM
corey8084
Sep 17, 2015 02:56 PM
mackjar66
Sep 14, 2015 01:17 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
