Wheel rock
Old May 15, 2009 | 03:30 AM
firebird1992's Avatar
Car: 1992 firebird
Engine: V6
Axle/Gears: 10 open 3.42
Wheel rock
so i went for inspection to day and the guy lifted the can and said i have dad wheel rock like wtf is that he showed me and it looked as if the wheel was very loose the bolts are torqued to spec and everything but what cause both wheels to shake like that
Old May 15, 2009 | 04:00 AM
iroc_valencia's Avatar
Re: Wheel rock
Do you have stock rims ?
Your car originally has spacers ?
Are torqued right ? , check it out , IIRC , there's different torque settings for the different stock type rims , for example IROC alum rims. are torqued diff than the Z28 wheels.
Greets
Old May 15, 2009 | 04:08 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Wheel rock
I assume you mean a front wheel, if you've got a rear wheel that rocks like that, then your axle bearings are shot. On the front end, there are several things that can cause the wheel to have play in it. It's easier to pin down if you jack up the front and remove the wheel, so you can see which parts are moving. I would suspect a steering part (inner/outer tie rod or center link), or possibly a worn upper strut mount.
Chiknhawk
Wheels and Tires
Jan 29, 2017 10:19 PM
JB82Z-28
Exterior Parts Wanted
Oct 6, 2015 09:05 AM
Fionnla
Wheels and Tires
Sep 11, 2015 11:07 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
