Front Swaybar bushing size?
Old May 20, 2009 | 11:23 AM
Blackknight's Avatar
I measured my swaybar and it comes out to be 36mm, can this be? It's an 89 TA non LS1. Does this mean I need 36mm bushings? I checked on Spohn's website and under the 36mm bushings it sais the LS1 package.
A bit confused here any help is appreciated!
Thanks.
Cedric
Old May 20, 2009 | 11:26 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: Front Swaybar bushing size?
Should be WS6...
Old May 20, 2009 | 11:30 AM
Yes I have the WS6 option, does that mean the size is correct? So if I get the 36mm bushings I'm getting the right ones? First time doing this
Old May 20, 2009 | 11:36 AM
84redta's Avatar
If you infact have the WS6 option, it is a good chance that you have a 36MM sway bar up front and that you measured correctly, and as such would need a 36MM bushing.
Old May 20, 2009 | 11:43 AM
Thanks man sounds great
Old May 20, 2009 | 11:59 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
My guess is that it's the hollow 36 mm front and solid 24 rear combo.
JamesC
Orr89RocZ
Apr 25, 2016 08:28 AM
toronto formula
Nov 10, 2015 06:17 AM
ProtoMaster22
Aug 26, 2015 07:50 AM
TheExaminer
Aug 25, 2015 07:34 PM
knight72
Aug 10, 2015 09:32 PM
