coil spring spacers
Old May 16, 2009 | 09:07 PM
87whiteiroc's Avatar
Car: 87 Camaro
Engine: 5.7 350 TPI
coil spring spacers
im looking to put some global west coil spring spacers on my rear springs. trying to research all solutions to my fender rubbing. my rear is stock except for the 17x11 wheels. the question is will these work with a stock camaro suspension. the spacers will raise the rear about an inch and hopefully will end the rubbing. let me know what you guys think and if you have them installed on your cars
Old May 16, 2009 | 09:17 PM
Car: 87 Camaro
Engine: 5.7 350 TPI
Re: coil spring spacers
im going to look at getting new isolators as well wonder if the combo will do the trick or just go with one or the other
Old May 16, 2009 | 09:20 PM
Sledge84's Avatar
Car: '84 Z28
Engine: 383 Stroker
Let me know what you find. I'm having the same problem right now. I'm first going to try air shocks and see what that does for them.
Old May 17, 2009 | 06:34 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Moog 5665 rear springs will jack the rear up an inch plus.
JamesC
Old May 17, 2009 | 09:43 AM
Car: 87 Camaro
Engine: 5.7 350 TPI
thanks for the help again james im going to order the springs this week. ive got a lot of work ahead of me have to put in new springs replace my bent axle and install the subframe connectors. next couple weekends are shot
Old May 17, 2009 | 03:33 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
air shocks = really bad idea, dont use them
Old May 20, 2009 | 09:44 AM
Sledge84's Avatar
Car: '84 Z28
Engine: 383 Stroker
whats so bad about air shocks?
Old May 20, 2009 | 03:56 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
they put the entire weight of the car on the thin little piece of sheetmetal in the rear shock tower. That spot was never designed to support the weight of the car. It will eventually tear out.
MM2Robinson
Oct 1, 2017 09:16 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
lakeffect2
Sep 7, 2015 03:52 PM
Jlanz55
Sep 6, 2015 03:05 PM
