swapping drum rearend to disk rearend
Old May 22, 2009 | 02:42 PM
scoutsniper's Avatar
Car: 2000 TRANS AM
Engine: H,C,I LS1
Axle/Gears: 3.42 posi
my freinds got a camaro with a drum rearend and bad bearings. he has a disk rearend with 373 posi end to end. is it worth swapping to disks or getting the drum rearend rebuilt.
what would he have to do for the swap?
thanks.
Old May 22, 2009 | 03:25 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: swapping drum rearend to disk rearend
What's the 3.73 rear end from? If its from a thirdgen, it'll bolt right up. You'll need a disc/disc proportioning valve in place of the current disc/drum one he has, and possibly a brake line or 2 for the rear.
Old May 22, 2009 | 03:36 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Some info in the following link may be useful:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
86White_T/A305
Aug 17, 2015 12:16 AM
