Picking up suspension parts friday from ARC
Car: 1992 Z28
Engine: Forged LS3
Transmission: T56 stage 2 clutch
Axle/Gears: 35 spline with 3.55 gears
Picking these up tomorrow!!!!!!!!!!!
http://www.americanracecomponents.com/82cacacapl.html
How do they look?
Thanks,
Robbie
How do they look?
Thanks,
Robbie
Re: Picking up suspension parts friday from ARC
How do they look?
Thanks,
Robbie
How do they look?
Thanks,
Robbie
Car: 1992 Z28
Engine: Forged LS3
Well.
I already have Lakewood 70/30 on the front. I also got the front k-member, Lower control arms, and a coil over kit from ARC a couple of weeks ago!
I am working on doing a LS1 brake up grade on the front & all new suspension stuff on the front!
Thanks,
Robbie
1fas92
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Is there enought room for the strut to travel through that bottom plate? The one the spring sits in. If not, and the strut hits that spring plate, you'll have problems with bottoming out if you lower the car any at all.
Car: Jeep
Engine: small
Transmission: automatic
Axle/Gears: rear
The coilover plate has a 2.5" hole, most of the strut bodys seem to be 2" +/-.I have had the same basic st up on cars fot the past 7-8 years without any issues. HTH
