Do springs really wear out?
Old May 30, 2009 | 03:36 PM
Shroken's Avatar
Car: '85 Trans Am
Engine: 350 Crate Motor
Axle/Gears: 3.27 posi
I was checking my shocks the other day when I noticed that I can move the front of my car a great deal more than the rear. Its like jumping on the back of your grandma's car and it drops 3 inches. Ok not that bad on mine but its a huge difference that surprised me. The rear of the car feels solid; I can hardly rock it around. Sure theres a lot more weight in front to make it do this but what do you guys think?
Old May 30, 2009 | 04:02 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Do springs really wear out?
I think you need new struts.
JamesC
Old May 30, 2009 | 06:50 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Springs hold the weight of the car. Shocks control how much the springs move.
Springs can wear out and even break. All springs have a spring rate. How much they'll compress when a specific amount of weight is applied to them. After countless oscillations over the life of a spring, the spring rate will decrease. Normally this is noticed as sagging or riding too low.
Some factory springs such in an RS model have a soft spring rate to give a soft ride. Springs in a Z28 have a high spring rate to give a more firmer, aggressive ride.
Providing the spring rate is not too high, you can do a bounce test to check the shocks. Pushing down on the car, it should bounce back up then down to it's rest position. If it continually bounces, the shocks/struts are worn out and are not controlling the spring oscillations.
Old May 30, 2009 | 07:11 PM
Stephen's Avatar
Car: 87 GTA
What they said.....
Sounds more like a strut problem than a spring problem. Springs only or blown struts/shocks & the car can bounce up & down like a basketball (with the tires staying on the road, just the body bouncing).
Old May 31, 2009 | 04:30 AM
Shroken's Avatar
Car: '85 Trans Am
I replaced the shocks and struts about 30,000 miles ago and they still seem to be fine; like they say, you push it down and it comes up then down to rest. And like I said it isn't really that bad it just seems soft compared to what a performance car ought to feel like. Yeah these things are NEVER done.
Old May 31, 2009 | 09:36 AM
Stephen's Avatar
Car: 87 GTA
What brand shocks/struts?
If the car only comes up & down once, then settles....That is pretty normal.
Worse I've seen was a car that either had BAD shocks, or none at all. Pulled up to a red light...bounce, bounce, bounce, bounce.....Until the traffic clears & he took a right on red turn. And it wasn't no lowrider!
Old Jun 1, 2009 | 10:43 PM
Shroken's Avatar
Car: '85 Trans Am
Monroe Sense-a-trac. Shocks and struts were blown when I got the car, and that was one of the first things I fixed mechanically. Can't say how they compare to others but I'm very satisfied with them. No problems whatsoever.
Old Jun 2, 2009 | 11:55 AM
1Aauto's Avatar
Former Sponsor
I just broke two front springs in my DD 98 Altima(over the winter).Then again it's not made to toss into a corner to blow away a mini van.
87v6Bird
Jul 1, 2018 04:12 PM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
Dragonsys
Sep 25, 2015 03:51 PM
sandman92084
Sep 12, 2015 10:27 PM
