Has anyone run 900lb front springs?
Car: 1991 Z28 1LE
Engine: chev 350
Axle/Gears: 4.11
I have 1991 Camaro z28 1LE and I was looking for stiffer fronts than my eibach pro kit which is 714in lbs. Has anyone run these before. My rear springs are 190in lbs from Global west.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: Has anyone run 900lb front springs?
I believe the Eibachs are progressive, not linear - if so, the 714lbs-in is the max rate, not the nominal one. I'm running 750lb linear springs with a lightened front end, which is a really good combo with Bilsteins and a 36mm hollow bar. If you are having a front-rear balance problem, just get lower rate rear springs...
TA8487
Aug 11, 2015 09:02 PM
