That is that bar thats parallel with the driveshaft?
Old May 30, 2009 | 06:23 PM
magadith's Avatar
Car: 83 Trans-Am (Recarro)
Engine: 305 4bbl
Transmission: 5 speed manual
Its connected to the rear axle and is is along side the drive shaft and the other end is free floating at the back of the transmission. I ask because that bar is knocking up and down. Isn't there supposed to rubber to cushion it?
Old May 30, 2009 | 06:39 PM
HankL69's Avatar
Car: 85 IROC / 69 Firebird convertible
Engine: 5.0 / 350
Transmission: t-5 / WC t-5
Axle/Gears: 3.27 / 3.08
Re: That is that bar thats parallel with the driveshaft?
yes, there should be a rubber pocket that it fits into . I haven't been under mine lately to say exactly how or where it connects but I do know there is some kind of cushion.
Old May 30, 2009 | 06:51 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
That bar is called a torque arm. There should be a bracket and rubber bushing on the back of the transmission that the torque arm slides into.
Old May 30, 2009 | 07:46 PM
magadith's Avatar
Engine: 305 4bbl
Thanks. The bolt came loose from the bracket because I noticed that the threads that bolts in the transmission is stripped. It will turn but won't tighten. I used some high strength threadlock just to keep it from loosening from the vibration. But I also noticed that the rubber part is now missing somewhere on the road. I had some thick rubber that I used for a temp fix, but I guess I need to take a trip to the wrecking yard soon. Unless I can find that part at the auto parts store.
Old May 30, 2009 | 08:20 PM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
You can get a poly bushing for like 15-20 bucks you have to drill out 4 rivets for it though.
Old May 30, 2009 | 09:26 PM
AlkyIROC's Avatar
Car: 87 IROC L98
The polyurethane bushing is a lot better than the used factory rubber one you'll probably find in the junkyard.
Old May 31, 2009 | 12:50 AM
magadith's Avatar
Engine: 305 4bbl
Where can I get one?
Old May 31, 2009 | 02:28 AM
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
Axle/Gears: G92 3.23, G80, J65 disc
im not for sure but i think you can special order them from Auto Zone, but just do a search online for them, and you need to make sure you get the right one because there are 2 different ones.
Old May 31, 2009 | 02:37 AM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
www.summitracing.com www.jegs.com or any many of the site sponsors carry them.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
