Possible clearance issues
Old Jun 3, 2009 | 08:10 PM
ICESTORM's Avatar
Car: 1989 Camaro IROC-Z
Engine: 350 TPI L98
Would going up to a 17" or an 18" IROC rim with a 1" to 1.5" drop on an 89 IROC cause any problems? Thank you.
Old Jun 3, 2009 | 09:40 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: Possible clearance issues
i've heard that 17's with a 245/45 tire have no problems. Where you getting the rims from?
Old Jun 3, 2009 | 10:57 PM
ICESTORM's Avatar
Engine: 350 TPI L98
I have not done enough research to know where I will be purchasing the rims. I know I want to stick with the IROC look though. I will probably end up using Eibach 1" drop and 17s to play it safe. I really want to keep a stock look but fill out the wheel wells and give it an aggressive stance. I noticed you have Magnaflows, how are they? I was thinking of putting in Flowmasters with a high flow cat. I'd like an extremely aggressive rumble. Your thoughts? Thanks for your input 89ROC-Z
Old Jun 4, 2009 | 10:08 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
if 245/45R17s fit, I would think that 245/40R17s would fit as well. They are almost exactly the same size diameter/width.
New2Chevy
Sep 28, 2015 12:35 AM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
Accerrito22
Sep 5, 2015 09:34 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
