Rickety, loose, "old car" feeling
Old Jun 29, 2009 | 01:31 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
Just picked up my 88, the engine/trans are in great shape, but the car has the rickety, loose, "old car" feeling. Is that more of a shock, strut problem or a bushing, tie rod end, ball joint etc. problem? It doenst really have a "bouncy" feeling, but going over bumps it feels rickety. Thats really the only way I can explain it. Any help you can give me would be greatly appreciated. For instance, my parents have a S2000 and it just feels "tight", the camaro feels loose. I know I will never get the S2000 feel out of the camaro, but I want to fix it so that it feels a little "tighter" than it is.
Old Jun 29, 2009 | 02:01 PM
1Aauto's Avatar
Former Sponsor
Re: Rickety, loose, "old car" feeling
If the steering wheel has allot of play in it,it may be time to rebuild the front steering pieces.
We offer a nice kit that should tighten it up for you making the steering tighter as it once was.
Here's a link to our steering rebuild kit,we should have them back in stock soon.
Chevy Camaro Steering Rebuild Kit
Old Jun 29, 2009 | 02:12 PM
1988-305-tbi's Avatar
my car felt loose and unpredictable, it corned ok but sudden lane changes at freeway speeds was down right scary, i have rebuilt/ replace every steering susspension component on my car. evry little bit helps but for me the panhard relocation did the trick, my car was lowered and it through the panhard off level and the car was the worst handling vehicle i had ever been in, got it nice and level and the car handles good that and adjusting the steering box made the biggest differences a new idler arm should help too, SFC's make the whole car feel newer/ stiffer
if your control arm bushing are original thats a problem right there
Old Jun 29, 2009 | 08:57 PM
Tpx's Avatar
Tpx
Car: 1982+1988 Z28 Camaros
Engine: 1982=350 carb 1988=383 Carb
Transmission: 1982=4 speed T-10 1988=6 speed T56
Axle/Gears: 1982=stock
Check bushings first, they are usually crumbling and rock hard after almost thirty years. Rebuild the steering, that helps A LOT! Entertain the idea of stiffer shocks and springs, that makes a WORLD of difference!
Old Jun 29, 2009 | 09:31 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
If it is a T-top car, then I would get subframe connectors (Weld-in only! Bolt-in are a waste of time/money IMO.) I think everyone else is also right on the money. After 21 years anything that is made of rubber or sustains wear, such as tie rod ends and bushings, will be worn out or hard and brittle. Subframe connectors will make the car feel more "Solid" and stiff.
Good luck!
Old Jun 30, 2009 | 10:16 AM
UMI Sales's Avatar
Hello
I noticed that you are looking into a possible suspension upgrade! Well I just wanted to leave you know that UMI Performance has a wide variety of aftermarket suspension components that might be of interest to you! Lets face it the cars that we are dealing with the bushings are dry rooted and sleeves are rusted down to nothing. Below is a link to show you what all UMI Performance has to offer to get your ride back to a quality!
http://umiperformance.com/82-92fbody
If you have any other questions feel free to ask and I will be more than glad to help!
Brad
Old Jul 1, 2009 | 10:19 AM
7SEALS's Avatar
check your floors too. If they are rotted out and nasty then it will feel very loose. When I got my floors redone I could feel a world of difference. I also did all my tie rods/idler arm/alignment and it feels really stiff now.
Old Jul 1, 2009 | 10:55 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
The floors are good. There is no rot on the car. Im gonna look into the tie rods/idler arms.
Ed1LE
Sep 30, 2018 09:14 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
gord327
Sep 29, 2015 10:18 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
