Wheel Bearing?
Old Jul 2, 2009 | 03:03 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
Wheel Bearing?
I was driving around yesterday and all of a sudden the car pulls HARD to the left and when I pulled over there was ALOT of smoke coming from the brake area. What else could it be because I though bearings going out would give atleast a little warning and not just go out like that.
Old Jul 2, 2009 | 03:09 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Wheel Bearing?
the rotor assembly could have seized to the spindle.
Or you brake caliper locked up. It could be as simple as a bad flex line
Old Jul 2, 2009 | 03:12 PM
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
Re: Wheel Bearing?
Alright anything I can do to test?
Old Jul 2, 2009 | 03:21 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Wheel Bearing?
yea, jack the car up and see if you can turn the wheel.
if no, pull the wheel off.
remove the caliper, if it come off relatively easily, its still working properly.
try to turn the rotor, if it doesnt move with the caliper off, the bearings have welded to the spindle.
J-money
Jan 4, 2019 09:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
