front end not centered?
Old Jul 8, 2009 | 05:28 PM
bmxerboi221's Avatar
Car: 1988 Firebird
Engine: soon to be 3.4/3400
From looking at it looks like the front end is not centered. Like the passenger wheel seems closer to the fender than the driverside. Cars lowered about 2 inches I had an aliegnment done after I lowered it a year ago, also passenger caliper is warped so it shakes quite a bit when braking. Will getting another alignment fix it?
Old Jul 8, 2009 | 06:38 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: front end not centered?
an alignment will not move the wheel in or out, in fact there is no adjustment in and out.
is the entire wheel out further, or just the top? that could be an alignment issue
It could be an illusion, or the car is wrecked and "fixed", or a fender is bent slightly and bulged out further than the other. Could be a handful of other possibilities, but if nothing is obviously damaged or broken, there is nothing you can do about it.
Old Jul 8, 2009 | 07:29 PM
1988-305-tbi's Avatar
maybe the front/rear wheel offsets are different, and a front wheel is on the rear, and vice versa
Old Jul 8, 2009 | 10:27 PM
Car: 1988 Firebird
Naw, im running c6 wheels. 18"s up fron 19"s out back. From what i know the cars never been wrecked. Another question i have, is when im rolling slow and brake hard there is a popping noise coming from the driver side front wheel. Any idea what this could be?
Old Jul 10, 2009 | 09:59 AM
BMR Sales's Avatar
Former Sponsor
Check to see that everthing is tight. That popping could be a ball joint, strut bolts,bushings, or sway bar related.
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
bellez77
Sep 5, 2015 08:39 PM
