best aftermarket suspension vendor
Old Jul 28, 2009 | 01:41 PM
nick86bird''s Avatar
Car: 1984 Trans Am
Engine: 383 4 bbl
Axle/Gears: eaton posi w/ 4.11's
What is the best aftermarket suspension vendor. i know Spohn is top for our cars as well as UMI but i dont want to mix and match between 2 or 3 different vendors.
Old Jul 28, 2009 | 05:59 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: best aftermarket suspension vendor
its pretty much preference. I like UMI, other people like spohn. You also need to keep in mind that parts you need, Spohn offers some things that umi does not offer right now. No reason not to mix and match, if they are all the same color who cares? i have a mixture of parts on my car and everything is fine.
Old Jul 28, 2009 | 06:24 PM
PURPLEFORMULA's Avatar
Car: '89 Formula Firebird
Engine: LSX-451 / 705HP
Axle/Gears: Moser Ford 9" with 4.30
Spohn all the way.
Eric
Old Jul 28, 2009 | 09:38 PM
1988-305-tbi's Avatar
as far as SFC's go it's UMI hands down the square tubing is much much stiffer up and down and side to side than round SFC'S besides that it's just preference
Old Jul 29, 2009 | 10:15 AM
1Aauto's Avatar
Former Sponsor
If you need to tighten up the steering too we offer this kit for that.
Camaro Suspension and Steering Kit
Old Jul 29, 2009 | 01:18 PM
Car: 1984 Trans Am
Engine: 383 4 bbl
yea sfc's are first on my list. ive heard a lot of good things about umi and square tubing being stronger. does the same go for boxed LCA's? Also who sells performance springs that dont lower our cars but are better than stock?
Old Jul 29, 2009 | 01:30 PM
moog sells the iroc replacment springs stock height and a little stiffer than factory
Old Jul 29, 2009 | 01:37 PM
Car: 1984 Trans Am
Engine: 383 4 bbl
HOW ABOUT THOSE MOROSO TRICK SPRINGS ARE THEY ANY GOOD? I KNOW THEY ARE FOR DRAG RACING SO STREETABILITY IS PROBABLY AN ISSUE WITH THEM.
Old Jul 29, 2009 | 09:37 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
LIKE YOU SAID, THEY ARE DRAG SPRINGS, I WOULD NOT USE THEM ON A STREET CAR. DONT TYPE IN CAPS ITS LIKE YELLING AND ITS REALLY REALLY HARD TO READ
Old Jul 29, 2009 | 09:40 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
all spohn here.
Old Jul 29, 2009 | 10:01 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
WHAT?! IT MAY LOOK UNINTELLIGENT BUT I DON'T THINK IT'S HARD TO READ. SHOULD WE JUST YELL THE ENTIRE CONVERSATION AND FORGET LOWER CASE ALTOGETHER?!
Old Jul 30, 2009 | 11:08 AM
BMR Sales's Avatar
Former Sponsor
Don't forget about BMR. We have a complete line of suspension parts from k members and a arms, frame connectors, and all of the rear suspension pieces that you would need for any type of driving that you might do. We also have k members to put an LS1 motor in the third gens or with no motor mount provisions for use with a motor plate. BMR has been in business for over 10 years and our tech dept is one of the best in the business. Here is a link to our site and if there are any questions please let me know.
http://www.bmrfabrication.com/index.htm
Old Jul 30, 2009 | 11:55 AM
Guest
Guest
Posts: n/a
That philosophy is just silly- why not?
if anyone is interested in my opinion of products, I will come back into here and list each and every product I would buy right now for a new build when it comes to suspension peices. yes, I do like alot of what Spohn sells, and I can back it with why, but I also like alot of other companies products he does not make or sell.
Lets me know if my opinion is wanted or appropriate here and I will list my favorite parts and why.
Dean
Old Jul 30, 2009 | 12:16 PM
yea, i wouldn't mind hearing some products you prefer and why.
Old Jul 30, 2009 | 02:18 PM
TackleDummy's Avatar
Dean
I'm in the planning stage and wouldn't mind hearing your opinions on your favorite parts. More info from those with experience is always a good thing.
Old Jul 30, 2009 | 04:25 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
SURE, SOUNDS LIKE A PLAN
it gets a bit hard to rear when its a long paragraph, and its a little annoying
Old Jul 30, 2009 | 06:30 PM
Car: 1984 Trans Am
Engine: 383 4 bbl
thanks for the input guys. dean if you wouldn't mind posting up your list im sure some other members and i would appreciate it. o btw sorry about the caps that post was done on a computer at work where we always use caps lock.
Old Jul 30, 2009 | 08:53 PM
I agree, a long paragraph makes it harder to read. gets annoying too.
not a problem, we we're just having fun more than anything.
Old Aug 1, 2009 | 12:58 PM
Guest
Guest
Posts: n/a
My parts purchase choices and why.
(Some of them I will 'Make My Own' (MMO) but will detail whos peices I would buy to put the par together making certain heavy duty parts that are lightweight and not offered as a unit.)
front to rear-
*Aluminum bumper support (factory hard to find, I had one)
*Wonderbar- Spohn with preload adjustment.
*Steering box- Lee performance boxes
*Tie Rods- MMO with Coleman Racing parts and Allstar Racing parts utilizing bumpsteer outers and inners shim studs and top notch QA1 rod ends (When I say top notch, I mean the expensive 3pc HM-T series)
*Steering shaft- Flaming River shaft and u-joint couplers all stainless
*Hotpart strut mounts- Different camber/caster settings for more precise dial -in. liffetime gaurantee on sperical bearing.
*Kmember- The factory strong unit. It is solid and will take a hit.
*Strut mount brace- MMO 3pt out of Coleman Racing (CRP) aluminum tierods and QA1 Rod Eyes and Linkage Adjusters. Custom welded tabs onto the hotpart strut mounts for STB mounting.
*front struts- Varistrut double adjustable. Lightweight aluminum design. Custom valving availiable.
*Spindles- Racecraft 2" drop spindles- lightweight
*A-arms- Spohn tubular adj w/ Delrin joints (these are hot) and spring boxes. NOTE1:Can fudge slightly more camber and caster without moving the spring into the side of the can. NOTE2: Remove balljoint from Spohn and replace it with a QA1 zero friction balljoint
*Front brakes- check my signiture page if you have never seen the custom Wilwood package I built - custom GW aluminum g-body hubs, all the trick stuff- extremely large and lightweight. 6pistom calipers w/ 2pc aluminum hat 13x1.25 rotors.
* Springs- custom rates probably in the 950 fronts and 250 rear ranges.
* Weight jacks- MMO Coleman racing affixed to top side of cans and adjusted through engine compartment.
*Swaybars- HRE custom made bars with 'in cockpit adjustments' and aluminum lever arms to a-arms, QA1 rodends for links male to female.
*Cage- Grace racing out of Japan
*SFC's- Spohn perimeter type with Grace cage tied into them through floorboard
*TCI 6 speed auto with paddle shifters- handles 850 hp
* ACPT carbon fiber driveshaft- had one of these already light unsrpung weight, strong, light rotation mass. 4.8lbs
*Tqarm- Global West Traclink- strong chassis mount, great clearance, lighter pivot weight (unsprung), shorter length to help get off the corner and reduce nose dive going in. (Road race setup) (Drag race- BMR Extreme)
(I recommend Spohn units though for most people that do not understand reprocussions of shortening the length and the parts & setup changes required to make it work- Spohn makes great fabbed products. He has been a frontrunner in the industry and uses great materials and processes in fabrication. He's been around a while- alot of copycats that do well, but I like what I have seen in Spohn over the years- he is innovative and generally the 1st on the block with good new ideas).
*Rearend- Currie Trac9 lightweight chromemoly housing w/ alum LPW rear cover, aluminum 3rd member, 3:70 lightweight gears, lightweight pinion yoke and misc, Platnum Trac carrier.
*Relocation brackets for LCA's- BMR bolt-on units "also welded". They position well and are strong. Regular weld on types can be welded with poor clocking and cause geomerty/alignment problems. NOTE:I also like the added bracing to the shock mount for coilover addition support. Yes it adds unsprung weight, but I like the strength add factor here to reduce flexing of shock coilover mounts.
*Rear shocks?- (Smiles) Penske 4-ways if I couild afford them. really though, any good doulbe adjustable aluminum body coilover (QA1, Koni, Afco, Proshocks,etc.)
*Coilover rear setup- Spohn reinforcement plates.
*Panhard -("If I used one"that is.-I would go to a different setup, I would build that Mumford link I posted on here.) MMO panhard rod out of Coleman aluminum Trailing arm and Spohn Delrin assemblies on both ends.
*Rear swaybar- HRE adjustable "in-cockpit controlled" swaybar mounted sprung weight on the new Mumford link with aluminum lever arms extending to axle housing and QA1 rodned links. (Swaybars are all basically just a size thing. Any manufacturer is decent for the most part with slight variances. Factory bars are hollow and light, but break over time with corrosion. Just pick whatever from whomever- it is a fine tunning item based on chassis roll weight and spring rate choice. To each his own choice)
*rear brakes- The Wilwood setup I had 4piston fixed caliper, 12.20 x.81 two pc rotors, however, all rotors would be dynamically mounted instead of static mounting like I had for pad runoff in extreme cornering forces.
*rear LCA's (wer control arms) MMO out of Coleman trailing arms, Spohn Delrin 'front' mounts assemblies, and Qa1 'rear' rodend HM-T series.
*Then also of course I would make various chassis braces accordingly like I did on my other Camaro .
*Wheels- nothing larger than a 17" diameter. larger gets too much metal and too little tire and starts increasing not only unsprung weight, but also massive rotational mass which hinders acceleration and braking.
Dean
To my knowledge, that is the best parts availiable and how I would spend my money today if building another 3rd gen.
Old Aug 1, 2009 | 07:39 PM
charlie31603's Avatar
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
Got a lot of Hotchkis stuff on mine. Adam :-)
Old Aug 2, 2009 | 08:19 PM
Car: 1984 Trans Am
Engine: 383 4 bbl
Hey thanks for the input. Dont know if i will go as in depth as you Dean but very good isight nonetheless
Old Aug 3, 2009 | 08:30 AM
UMI Sales's Avatar
Hello
I noticed that you are interested in some aftermarket suspension parts. I just wanted to leave you know that UMI Performance has a wide variety of parts that are made right here in our own facility in the USA! Below is a link to show what all we have to offer.
http://www.umiperformance.com/catalo...=index&cPath=6
If you have any other questions feel free to ask and I will be more than glad to help.
Brad
Old Aug 3, 2009 | 08:50 AM
hey, welcome to tgo tackledummy.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
Ed1LE
Sep 30, 2018 09:14 AM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
meeklay812
Oct 1, 2015 03:46 PM
92projectcamaro
Sep 29, 2015 07:07 PM
