What Springs To Lift My 90 RS?
Old Aug 15, 2009 | 10:56 PM
RS90CAMARO's Avatar
I'll probably catch hell for this but I want to lift the front of my camaro higher. My ride height right now is 26" from the ground to the fender lip and I like to raise it up a few inches, I'm looking at moog springs but I'm not sure which one is right for what I want I'm thinking 5610. I have a V6 auto trans and a/c.The tires I'm running are 235/60R15 tires on 15x7 rims. Stiffness doesnt matter to me. I've heard of people lowering these cars but I've never seen one lifted higher. I'm going off of this website for my spring info http://jeffd.50megs.com/Moog_Spring_Page.htm
Old Dec 4, 2009 | 01:42 AM
RS90CAMARO's Avatar
Re: What Springs To Lift My 90 RS?
I got my spring choice narrowed down to 4. I was hopeing someone could tell me which springs would raise my car the highest?
Part Number 5610
Inside Diameter 4.080
End Type 1 Square
End Type 2 Tangential
Bar Diameter 0.687
Install Height 11.00
Load in Pounds 1750.0
Spring Rate 424.0
Free Height 15.19
Part Number 5608
End Type 1 Square
Bar Diameter 0.687
Load in Pounds 1640.0
Spring Rate 424.0
Free Height 14.88
Part Number 5600
Inside Diameter 4.090
End Type 1 Square
Bar Diameter 0.671
Load in Pounds 1600.0
Spring Rate 347.0
Free Height 15.63
Part Number 5606
End Type 1 Square
Bar Diameter 0.687
Load in Pounds 1530.0
Spring Rate 421.0
Free Height 14.63
Old Dec 5, 2009 | 06:32 PM
RS90CAMARO's Avatar
Now I got it narrowed down to 5610 and 5608. I think I'm going to install the 5608 moog shows that there the heavy duty version for my car and it should put it higher then what I have now.
Old Dec 5, 2009 | 09:10 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
once you do this post up some pics because i am wanting to do the same thing
Old Dec 5, 2009 | 09:54 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
just doing a stock replacement will lift the car back up. these cars in their newest form are 17 years old, these springs are ragged and have drooped over time. no doubt you'll regain stock ride height.
the 5600 is a stock replacement, the 5608 is a HD version. you'd be fine with either in my opinion as they'll both have the same installed height. for whatever reason, the 5608's are cheaper though.
you could go to a 5610, which is the HD version for a v8 car. they'd raise the car up a bit.
Old Dec 5, 2009 | 10:20 PM
RS90CAMARO's Avatar
Thanks for the reply's I think I'm going with the 5608, it does show the 5610 was used in 91 for a v6 with a/c and auto but v8's for the other years, I wonder why they only used them for one year in a v6? I plan on taking pictures and doing a writeup for the install.
Old Dec 7, 2009 | 04:32 PM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
I bought the car thinking it was all stock, but if your measuring 26", I'm thinking twice. My car sits 28.125 level, on front and rear.
Old Dec 7, 2009 | 05:32 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
thats how i want mine what size of tires do you have
Old Dec 7, 2009 | 05:38 PM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
kuhmo 245/50r16
Old Dec 7, 2009 | 07:13 PM
RS90CAMARO's Avatar
I compared my tires to the tires your running and it looks like mine are only a 1/2" taller then yours. I think 28" is the correct ride height for these cars. I'm almost positive that mine has been lowered. I will try and post a picture tomorrow, right now its raining and it might snow.
ZZ3Astro
Aug 13, 2019 12:57 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Nervous2
Oct 8, 2015 10:53 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
anesthes
Sep 21, 2015 10:24 AM
