Do These Cars Have Alignment Problems????
Old Aug 21, 2009 | 01:03 PM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
I have an 89 Iroc and I just had it aligned last summer after I put new tie rod ends in and already the inside of my front tires are bald. I also have an 87 sport coupe that I drove for maybe 4,000 miles without any issues. Is there something up front I should be looking for? Thanks.
Old Aug 21, 2009 | 03:45 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Do These Cars Have Alignment Problems????
balljoints could be bad, strut mounts could be shot too. It is also possible you got a bad alignment. Where did you go? You should not be eating tires that fast.
Old Aug 21, 2009 | 03:52 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Original owner and only two frontend alignments in 22yrs. One after 15yrs to check if everything was correct and the other this year when I replaced all the steering parts. So I would say they hold there wheel alignment.
Old Aug 21, 2009 | 10:02 PM
Car: '89 IROC-Z
Engine: LSx
My balljoints are good and so are my strut mounts. I went to VIP. I got new tires and I'm going to have it aligned again and see what happens, its deffinatly possible I got a bad alignment.
Old Aug 22, 2009 | 09:21 AM
Happy Fun Me's Avatar
Engine: T.P.I. 350
Transmission: 700r4 Auto
I've done alignments for over 5 years and driven my camaro for 10 and i'd say these cars have no alignment problems. It's got to be a bad part or bad alignment.
Old Aug 22, 2009 | 09:31 AM
Stephen's Avatar
Car: 87 GTA
Replaced all 4 of my tie rod ends at home & eyeballed them, back to where the old ones came off, never got it professionally aligned. That was 2 years ago & the tires are still plenty happy.
So whatever your problem, it is just "normal" for 3rd gens. Either they did a bad job, or something else wore out, causing your tire problems.
Old Aug 22, 2009 | 12:54 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
yeah these cars are sweet. im going to rebuild my front end in the next month when i cools down. try jacking up the front under the kmember and clock the wheels in the rear. with the front in the air, try the wiggle test to see if maybe your bearings are out or you have excessive endplay. sure your strut mounts are ok, but that guy was asking about the strut mount alignment. what kind of a rebuild did you do. center link, idle arm, pitman arm, tie rod ends, inner tie rods, springs, struts, steering box, balljoints, bearings, tie rod ties, front control arm bushings, sway bar bushings, upper strut mount bearings. it is over 20 years old..
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
mustangman65_79
Aug 8, 2015 12:07 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
