Relocation Brackets
Old Aug 27, 2009 | 05:01 PM
426 Wedge's Avatar
Car: 86 WS6 TransAm
Engine: LG4 4BBL
Transmission: T5WC
Axle/Gears: 327
Relocation Brackets
Why are there 2 types, bolt on or weld. Are they both the same in terms of strength and duability? Does one transfer the load better during cornering?
Old Aug 27, 2009 | 08:39 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Relocation Brackets
Originally Posted by 426 Wedge
Why are there 2 types, bolt on or weld. Are they both the same in terms of strength and durability? Does one transfer the load better during cornering?
neither will perform better or worse. both really should be welded on, the bolt on ones just allow you to bolt them on and take it somewhere to be welded. They are for correcting geometry after lowering the car, the LCA should be parallel. If you use the lower holes, you can improve straight line performance, but your handling will suffer.
Old Aug 28, 2009 | 09:00 AM
UMI Sales's Avatar
Hello
Like mentioned above! They both perform the same. We offer both weld on and bolt on for what is easier for the customers capabilities. Below is a link to show you what UMI Performance has to offer!
http://www.umiperformance.com/catalo...6ru86m320sgna2
If you have any other questions feel free to ask and I will be more than glad to help!
Brad
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
armybyrd
Sep 26, 2015 03:37 PM
