Torque arm needed ?
Old Sep 2, 2009 | 05:35 PM
ziggy56's Avatar
Torque arm needed ?
Do i need the torque arm ? I have no mount hookups for it on my new tranny i have put in the camaro and everythime I hit the brakes it grinds on the ground, then when i let off them it hits the chassis. really just want to drive it.
Old Sep 2, 2009 | 05:54 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Re: Torque arm needed ?
Let me think about that a bit...
YES
The torque arm prevents the rear axle from rotating under conditions
of acceleration & braking. Possible side effects are:
-- pinion yoke chewing a hole in the floor
-- twisting the shock mounts off at the axle
-- possibly extracting the drive shaft from the transmission
Go ahead, ask me how I know this.
Old Sep 2, 2009 | 05:56 PM
ziggy56's Avatar
could i get some more information ? I have only owned trucks so I have no idea what it does. It doesnt have anywhere to bolt to now that I have changed the tranny.
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The car was designed for a torque arm, so, as mentioned above, yes! The arm keeps the rear end from rolling upward. Every thirdgen trans will have provision for the torque arm. Advertise in the classifieds for one.
JamesC
Old Sep 2, 2009 | 06:04 PM
ziggy56's Avatar
JamesC
ah, well then I guess I need to buy an aftermarket one ? or can the stock one be made to fit my car ?
Old Sep 2, 2009 | 06:08 PM
JamesC's Avatar
No after market pieces that I'm aware of. As I mention above, all thirdgen trans will have a mount of the arm.
JamesC
Old Sep 2, 2009 | 07:02 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
JamesC
what? is that a brain fart james or are we on different pages?
there are tons of options for torque arms and mounts, all depending on what trans you have. Check out UMI performance, Spohn Performance, BMR fabrication, jegster, global west, ect.
You will most likely be looking for a tunnel or crossmember mounted torque arm, since you apparently dont have a mount on your trans.
Old Sep 2, 2009 | 07:33 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
What Transmission are you using? And out of what?
Old Sep 2, 2009 | 08:51 PM
JamesC's Avatar
Semi brain fart--I was thinking of the OE mount.
JamesC
Old Sep 2, 2009 | 09:08 PM
Pocket's Avatar
Car: 91 Trans Am
He could use the Hurt or B&M crossmember mounts instead of a whole new TA/X member package
Old Sep 2, 2009 | 10:22 PM
ziggy56's Avatar
I am using a 700r4 out of my pickup truck, took the tail back housing off both trannys and they seemed to fit so will put the camaro tail housing on it, camaro one had a speedometer port and my truck one instead of the speedometer has a magnet ? I just put the magnet back in the camaro housing because my tail shaft didnt seem to line up with the gears on the spedometers teeth.
Old Sep 2, 2009 | 10:38 PM
Guest
Guest
Posts: n/a
you'll need to pull the tailshaft cover off again and tap the truck metal gear off (magnetic speedo reading gear) in place of the third gen plastic speedo drive gear, you can then use your original speedo driven gear assembly,
they tap right off the output shaft.
Old Sep 3, 2009 | 01:48 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Or... I would never put them on mine or any other car, but: http://www.summitracing.com/parts/LA...0/?image=large
Old Sep 9, 2009 | 12:18 PM
82TA_JAIME's Avatar
Car: 92 Camaro RS
Engine: 305 L03
Axle/Gears: stock
this is what i used for my th350. They have other ones too for other trannys.
http://www.umiperformance.com/catalo...roducts_id=299
Old Sep 9, 2009 | 06:35 PM
Pocket's Avatar
Car: 91 Trans Am
What a load of crap
It took a 3lb sledge and a special jig to get it off today
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
