Spohn Rack & Pinion Kit
Old Sep 3, 2009 | 12:50 PM
89_RS's Avatar
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
Does this look like it could be the answer to all us AX's out there who want a rack & pinion that works just as good as the stock steering?
http://www.spohn.net/shop/1982-1992-...GM-F-Body.html
Old Sep 3, 2009 | 05:56 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
Re: Spohn Rack & Pinion Kit
That setup is sick!
Old Sep 3, 2009 | 06:52 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
its a manual rack, and does it have the proper travel to retain the stock turning radius? Looks good though,
Old Sep 3, 2009 | 08:41 PM
89_RS's Avatar
Car: 2003 F-150
Transmission: 4R70W
According to Spohn, its 3.75 turns lock to lock.
*EDIT*: A quick search revealed that the stock steering is 3 turns lock to lock.
Old Sep 4, 2009 | 02:36 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
actually the quick ratio boxes are 2.25
Old Sep 4, 2009 | 07:20 PM
89_RS's Avatar
Car: 2003 F-150
Transmission: 4R70W
I was talking about the stock power steering. I found that info over on NastyZ28, the range of lock to lock boxes was in between 2 and 3 with a majority of them being 3 turn power steering boxes.
Old Sep 4, 2009 | 07:32 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
im pretty sure the slow ration boxes in 3rd gens were either 2.75 or 3. But still, this rack is 3.75 turns, so it will work, but its not the best for a AX car, you need a faster acting system.
Old Sep 4, 2009 | 10:19 PM
89_RS's Avatar
Car: 2003 F-150
Transmission: 4R70W
It's a big step in the right direction though.
Old Sep 11, 2009 | 09:41 AM
SomeGuy25thZ's Avatar
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
ANyone know of a manual rack with a quicket steering ratio? I am about to buy this kit but 3.75 turn to turn is too much.
Old Sep 11, 2009 | 11:50 AM
89_RS's Avatar
Car: 2003 F-150
Transmission: 4R70W
AFAIK, this is the quickest rack avaliable for a Thirdgen.
Old Sep 11, 2009 | 02:47 PM
Car: 1992 z28
do you mean quickest bolt in rack? Because there has got to be a manual rack and pinion setup with a quicker steering ratio. I am not worried about making custom mounting tabs to the K-member. Universal joints can be purchased as well as tie rod ends. Althought I wonder if all this trouble would end up costing more than Spohns setup which would then make that more appealing. Im just trying to think of turning the wheel almost two full turns to lock from center... seems kind of excessive.
Old Sep 11, 2009 | 04:34 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
3rd gen quick ratio boxes are the 2.75 l-to-l units, offered as part of
the suspension upgrade option. (On birds, W-6 I believe.) Standard
ratio is 3.75. All are power assist. (I may be a bit off on the decimal
value, but its definitely less than 3, and almost 4 respectively.)
Old Sep 11, 2009 | 05:58 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
um no, actually the quick ratio is 2.5 turns, standard is 3-3.5 turns, slow is 4-4.5 turns
Old Oct 9, 2009 | 01:42 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
what he said.
Old Oct 9, 2009 | 05:33 PM
kowalzekc's Avatar
Umm BMR sells one that is 3 turns lock-to-lock which seems more appealling the 3.75 or whatever the other one is. But if you are auto-X and want alot faster, then break out a hammer an tourch because custom is the way then.
Old Oct 9, 2009 | 06:55 PM
soultron's Avatar
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
If this set up was faster, you'd have to be in a crazy high class to run it.
Nick McCardle
Sep 10, 2015 08:36 PM
luvofjah
Sep 10, 2015 10:41 AM
87camaro87
Sep 9, 2015 10:29 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
