tire rubbing when i turn
Old Sep 7, 2009 | 10:50 AM
Dustin Fitch's Avatar
Car: 91 Firebird
Engine: 3.1
i got this 91 fbird from a buddy of mine. I noticed when i got it that the tire rubbed so bad when i got it that it had broke the frame. In fact when i turned the wheel it lifted the driver side of the front end up. I welded the frame, which was in the front of all the suspension so i wasnt too worried about stability. Someone told me that i needed to put a hydrolic jack in between the back of the wheel and the frame behind it and push the wheel forward. what do you guys think
Old Sep 7, 2009 | 07:05 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: tire rubbing when i turn
sounds to me like the car was wrecked and not fixed properly. You need to figure out whats bent, whether it be the frame, or the control arm or both. Putting a jack in the wheel well and trying to move things will just cause more damage. If you are that serious about fixing the car take it to a professional with a frame machine and have them fix it.
Vintageracer
Jan 10, 2020 05:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Fronzizzle
Mar 18, 2019 08:29 PM
B_Dubya
Aug 26, 2015 05:09 PM
Fronzizzle
Aug 9, 2015 01:15 PM
