Alston inner SFC install (welded with pics) and AC delete MSD ignition
Old Sep 7, 2009 | 11:03 PM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
The car has to sit level with the suspension loaded so I used ramps then supported the rear tires with wood until the car was level X and Y. Lots of cutting, beating, grinding, welding, priming, and painting later this is what resulted:
Old Sep 7, 2009 | 11:07 PM
Car: '91 LS6/T56/9"
Engine: LS6
Re: Alston inner SFC install (welded with pics) and AC delete MSD ignition
Old Sep 7, 2009 | 11:11 PM
Car: '91 LS6/T56/9"
Engine: LS6
Then the Blower motor/AC had to go to make room for the MSD ignition. Didn't get to finish tonight, but I'll be making a panel from sheet metal to mount the MSD stuff to. I also haven't thrown out my blower motor because I just might use an AC delete panel in the future to keep heat in the car.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
toronto formula
Nov 10, 2015 06:17 AM
actionj
Carburetors
Aug 16, 2015 09:51 AM
tartagliaz28
Aug 15, 2015 10:59 AM
