relocation bracket question
Old Sep 9, 2009 | 09:35 PM
fazt4life's Avatar
Car: 1991 camaro z28
Engine: 5.7 350
Axle/Gears: stock 3.23
recently i purchased edelbrock low control arm relocation brackets. i have read
many articles and treads on here but never found the answer i was looking for. i
know that they are nessacery on a lowered vehicle to correct the angle but i
want to put them on my stock height camaro. if i move the control arm to a
lower spot wont it greatly increase my traction from a stop? basically what im
looking for is....will it help my car or is it a bad idea? any info would be greatly
appreitated. Thanks
Old Sep 9, 2009 | 11:36 PM
1988-305-tbi's Avatar
Re: relocation bracket question
did you check out UMI before you bought thoose edelbrock parts..... they have the aswer to your question right on there website....http://www.umiperformance.com/catalo...693fkck7s544l6
short answer....YES
Old Sep 10, 2009 | 06:22 AM
ssean92's Avatar
Car: sold
I have always been told that you want the LCA to be leval with the ground, at no angle. I run mine on a stock height car in the middle hole.
Old Sep 10, 2009 | 09:25 AM
UMI Sales's Avatar
appreitated. Thanks
Hello
What we have experienced is when you install the lower control arm in the lowest location you get the best results in eliminating wheel hop and increasing your traction performance.
Brad
Old Sep 10, 2009 | 02:20 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
u want the LCA to be parallel to the ground when doing things like autocrossing... for drag racing/straight line all out performance u want the connection a the rear end to be lower than the mounting point on the subframe. too much angle can adversely affect drivability, cornering and braking etc.
also i dont kno if the edelbrocks are bolt in or weld in... i have UMIs bolt ins and i just welded them in after a yr of just being bolted on. if u plan on keeping the rear it would be wise to weld them on if they are bolt ons. what do they look like? got a pic or link?
Old Sep 10, 2009 | 02:21 PM
Car: 87 TA clone
Genopsyde
Nov 11, 2015 10:46 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
redmaroz
Aug 16, 2015 11:40 PM
