Ultimate 3rd gen suspension-part 1
Old Jul 5, 2010 | 01:36 AM
  #101
bobo5084's Avatar
Re: Ultimate 3rd gen suspension-part 1
So I have found that my 91 Formula is a bit of a diamond in the rough and have been doing some work on it. So far I have put new headers on it, larger edelbrock runners and intake manifold, along with edelbrock heads and some procomp roller rockers, and a 58mm throttle body. After replacing all that I am having issues getting the car to start and I am sure I just have the timing off by about 180 degrees (which I am going to work on tomorrow). The next project for the car is suspension, not to be an edelbrock slave but I was wondering if anyone had any thoughts on this kit http://www.jegs.com/i/Edelbrock/350/52063/10002/-1 or if there are any better suggestions out there. I do not plan on racing this car all the time, I will certainly be taking it to the strip a time or two though. So I am open to suggestion and looking forward to some good feedback. Fear not fellas, the next project after suspension is the brake system and finding a good true duel exhaust.
Old Jul 5, 2010 | 09:12 AM
  #102
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
overpriced crap, you can do better for less money elsewhere.
Old Jul 6, 2010 | 12:01 AM
  #103
bobo5084's Avatar
Well, I was looking for some feedback and suggestion. So if you have something better, please get me a link or part number so I can research it a bit
Old Jul 6, 2010 | 06:28 AM
  #104
Norm Peterson's Avatar
Car: '08 Mustang GT
Engine: 4.6L
Transmission: º º 0 . . . |-|-|
Axle/Gears: 8.8", 3.55
Sam Strano.
If you talk with him and explain what it is that you're trying to accomplish, I think he'll be able to put something together for you that gives you what you need without including things you don't need.
http://www.stranoparts.com/searchbymodel.php?ModelID=9
Norm
Old Jul 16, 2010 | 04:00 PM
  #105
TorqueWolf's Avatar
Car: 85 TA TTA clone
Engine: 355sbc (turbo planned)
Axle/Gears: 9 bolt rear disk
I see a watts linkage setup from that company Norm posted. Would that be benaficial at all over the panard bar setup or are the changes in roll center negligable?
http://www.stranoparts.com/partdetai...ID=0&ModelID=9
Old Jul 16, 2010 | 04:40 PM
  #106
Car: '08 Mustang GT
Engine: 4.6L
Properly set up, a Watts link makes the car behave more equally in left turns vs rights.
Roll steer effects are slightly different. Not necessarily better or poorer than a PHB, but different nonetheless.
A 3.5" range of roll center adjustment is significant. More than enough to warrant a change in rear sta-bar diameter. Probably more than the typical adjustable rear bar can compensate for.
Guy I know of from another forum changed his mind about the value of a WL over a PHB after driving a car that had its PHB swapped out for a WL. Before that, he admits that he never used to think a WL was worth the price . . .
Norm
Old Aug 8, 2010 | 09:23 AM
  #107
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Originally Posted by Vetruck
Tierods- Coleman racing aluminum tierods, Aurora extreme duty rodends PRMT series. Allstar bump steer outer tierod studs http://www.allstarperformance.com/product.htm?prod=219.
Allstar adjustable centerlink with offset bump steer alignment bushings
Factory spec'ed steering box rebuilt at Lee's performance boxes. Stay away from the AGR crap- trust me.
Flaming River steering shaft and Stainless u-joint swivels
Afco Zero lbs break away ball joints
What size endlinks would I need from the link below?
http://secure.chassisshop.com/partlist/5428/
Aslo which bump steer kit would I need?
Old Aug 9, 2010 | 03:05 PM
  #108
Guest
Guest
Posts: n/a
Old Aug 9, 2010 | 03:26 PM
  #109
Car: 89 IROC
Thanks for your help.
Old Aug 9, 2010 | 05:05 PM
  #110
//<86TA>\\'s Avatar
Car: 86 Trans Am
i didnt get them there, but the bump studs i have and most that i have seen are 5/8, so you would also need a 5/8 rod end, which just happens to be the same size and thread as the tie rod ends are stock.
Old Sep 27, 2010 | 12:46 PM
  #111
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
What's your opinion on Dymag Carbon Fiber wheels?
http://www.dymag-usa.com/automotive/#overview
Their wheels are less than half the weight of ours!
Old Sep 27, 2010 | 12:58 PM
  #112
SomeGuy25thZ's Avatar
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
but whats the cost? these would probably be far beyond anyones reach here.
and for daily driving i wouldnt want to use these. makes sense for road racing and such.
i wonder how they hold up when using some nice wide MT stree radials and getting a nice launch. if the tires holds on the to rim the rim will experience some serious torsion.
Old Sep 27, 2010 | 01:15 PM
  #113
Yeah i would not use these for the road (even though you can apparently use them for that) but i was thinking of getting a separate set of wheels JUST for the track (time trial circuit track, not drag). I think that's mainly what these are for, not drag.
As for the cost.. I agree a whole set is probly 2k+ .. ATLEAST.. so, not for the average enthusiast or even most thirdgenners would even pay for, but still, i am sticking to the notion of "ultimate handling" regardless of price :P
The weight reduction you get from this much reduced rotating mass is huge! This is purely race only .. Pair this with R1 BFG's (race rubber) and I can only imagine the cornering capabilities..
Old Sep 27, 2010 | 02:41 PM
  #114
Stephen's Avatar
Car: 87 GTA
Originally Posted by hellz_wings
......As for the cost.. I agree a whole set is probly 2k+ .. ATLEAST.
Probably $2k EACH minumum!
Old Sep 27, 2010 | 03:05 PM
  #115
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
I wouldn't be surprised if the price exceeds $5k a rim. Those rims have GOT to be expensive.
Better off with a set of light weight aluminum race rims as far as the pocket book goes. Unless you have unlimited cash, in which case please do buy and tell us how they work out.
Old Sep 27, 2010 | 05:53 PM
  #116
Guest
Guest
Posts: n/a
Old Mar 31, 2011 | 02:26 PM
  #117
89_RS's Avatar
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
Mods,
Please unsticky this as the pertinent data has been removed. This thread is no longer of value.
Old Mar 31, 2011 | 04:08 PM
  #118
What the hell happened to all the original text that Dean wrote?
Old Apr 2, 2011 | 01:34 PM
  #119
RyanEricW's Avatar
Yeah wtf. Ban the moderator, and prosecute the fraudulent seller.
Old Apr 2, 2011 | 04:45 PM
  #120
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by 89_RS
Mods,
I agree. I have no idea what prompted Dean to remove valuable text.
JamesC
Old Apr 2, 2011 | 06:36 PM
  #121
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
I think it might have something to do with the new text left on the very first post
Old Apr 2, 2011 | 07:17 PM
  #122
confucius101's Avatar
wow i defff have to reread all of this again only with out the JACK......lol
but here is what i'm thinking and working on a 91 bird with 3.1 i'm going to add a full turbo setup at some point next year
but for now i'm looking at a bunch of stuff from spohn k-member with coil over, toque arm, sfc, sways bars, wonder bar, lac 7 brackets & pan hard bar
i'm also adding an air ride pod kit
Old Apr 6, 2011 | 02:05 AM
  #123
Guest
Guest
Posts: n/a
ttt
Old Apr 6, 2011 | 11:20 AM
  #124
JT's Avatar
JT
Community Administrator
It's usually best to not act on one-sided information without knowing more of the story. Additionally, we aren't quite in a position to play the role of the legal system by judging as to what a member may, or may not, be doing outside of this forum that may or may not be legal. There is a process for that and ThirdGen.org is not exactly that process.
The issue that was partially aired here is a local issue between members of the SoCal groups as well as the SoCal forum - plain and simple - that did not belong in this thread. It's unfortunate that some seek attention by allowing whatever personal issue exists in the SoCal group and SoCal forum to spill into the technical sections.
The claim being made that a moderator censored Dean is not the entire story. In the SoCal forum, there was a recent post about recent Dyno Results from one of the groups in SoCal. Some tried to take the posted Dyno Results thread off-topic and derail it. Several posts were moderated - including Dean's. Moderation activity is logged and upon a quick review, I seen no "abuse" as claimed. When people make threats or insults, that's going to get moderated as it does not belong on this site and is against our simple policies.
What was not disclosed is that there has been a severe amount of drama posted to the Dyno Results thread, as well as the SoCal forum in general.
Posting to brag about crashing a reserved private event that was held at a local business, only to get escorted out of the business by management, is one of numerous drama posts that does not belong on this site. Posting to brag, or threaten, to arrive at a future meet with "friends" that would be interested in whatever behavior/activity of a SoCal group may or may not be taking part in is also another drama post that does not belong on this site.
Really, guys? This is the behavior that some in the SoCal group display that spills into the SoCal forum, and now onto our technical site. This is a small sample of the behavior that has been going on between some members of the SoCal group/forum and does NOT belong on this site. As the above stories were posted to the Dyno Results thread, they were moderated (removed).
This site is ThirdGen.org and not TruTV, MTV or Soapnet. For some reason, it's the same people in the SoCal forum/group that cannot get along with each other and stoop to such childish behavior for grown men. This behavior has been on both sides from the people in the SoCal forum/group as there's a split between groups. Both sides bare responsibility for this behavior. Dean has, apparently, taken a side in this matter. That's Dean's decision.
It's unfortunate that the actions between the SoCal groups, which is a local club matter, is airing and spilling onto this site and used to take technical content offline. Personally, I don't think it's a rational decision to withdraw technical content over personal issues that really don't belong on this site. The issues here are issues involving members in the SoCal forum and SoCal groups.
While the above is more of the story to help see what triggered this recent event, it's not even a fraction of the entire soap opera that has been the SoCal group/forum. It's just one storyline to illustrate the behavior taking place and is one to explain why some are upset. The local drama has no place on this site and has been stated umpteen times that it doesn't. However, some cannot play by the rules and some want attention to continue the drama that has been occuring between local members of the SoCal groups.
The people involved should be embarrassed for their behavior. However, given this has continued between the same people and the same groups in the SoCal area for some time (months to over a year), some, apparently, aren't.
This thread, and the other thread by Dean, have been locked as they were deliberately destroyed due to the drama involving some local groups/members of the SoCal area.
ex-x-fire
Jan 12, 2024 01:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
tricky1
Aug 23, 2015 01:17 PM
reiderz iroc
Aug 13, 2015 04:57 PM
