LCAs with zerk fittings?
Old Sep 21, 2009 | 11:41 PM
Stephen's Avatar
Car: 87 GTA
When I put my adjustable tubular LCAs, the "stock" LCAs I took off, had zerk fittings on the bushings. I've never seen ones like that before.
Any thoughts?
Old Sep 22, 2009 | 12:12 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: LCAs with zerk fittings?
pics? sounds like someone drilled, tapped and put a fittting on them?
Old Sep 22, 2009 | 12:49 PM
Stephen's Avatar
Car: 87 GTA
The brass look of the bushing housings, suggests that they are aftermarket, but I've never seen one with zerk fittings on them.
My 89 GTA didn't have then, but my 87 does. Had it been the other way around, I might have suspected that they were just improved in the later years.
Attached Thumbnails LCAs with zerk fittings?-p9220079.jpg   LCAs with zerk fittings?-p9220080.jpg   LCAs with zerk fittings?-p9220078.jpg
Old Sep 22, 2009 | 04:36 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
most likely aftermarket bushings
Old Sep 22, 2009 | 05:12 PM
Guest
Guest
Posts: n/a
Those are not factory bushings. See the extra rubber ring on the one side, at the bottom of the 1st+3rd pics? Those are energy suspension poly bushings. Either someone added the zerk, or bought them from one of the places that sold them with a zerk fitting.
Old Sep 22, 2009 | 05:23 PM
FueledSoul's Avatar
agree with both posts above
86Firebird86
Dec 26, 2015 07:21 AM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
