need help with tire rub...
Old Oct 11, 2009 | 10:31 PM
chase1900's Avatar
Car: 1992 Camaro RS
Engine: L03 305 TBI
i just bought some bfg tires and cragar rims. they stick out the sides a bit and when i hit bumps in the road or dips they rub. i need some advice on what to do. i think rolling the fender lip might help but i dont think it will stop the problem because it would still hit there. i did my share of searching on this topic and couldnt find much. the rear rims are 15x8 bs 3.5 i think and the tires are bfg radial t/a P275/60R15.
Attached Thumbnails need help with tire rub...-111009150341-01.jpg   need help with tire rub...-111009150213-01.jpg   need help with tire rub...-7035_158874551058_513176058_3238467_7429596_n.jpg
Old Oct 12, 2009 | 09:02 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: need help with tire rub...
You shold have got 4.5-5.5 backspacing. the 3.5 aint gonna fly.
Old Oct 12, 2009 | 09:56 AM
Stephen's Avatar
Car: 87 GTA
Do both sides stick out the same? Or just that 1 side? Is your car lowered any?
I had 285/17s on 5" bs wheels on (at stock height) and never rubbed once. But if the rear end is off to one side, you might need a new PHB, maybe just new bushings in the one you have.
Old Oct 12, 2009 | 07:45 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the problem is the backspacing, you need at least 4.5" of bs in a 8" rim for it to fit properly on a 3rd gen.
You can roll the fenders, but that wont solve your problems.
Or you can swap in stronger rear springs, raising the rear a little and keep the car from hitting the tire. Moog Iroc replacements would probably do the trick.
Old Oct 12, 2009 | 07:49 PM
94Pontiac's Avatar
Car: 1988 Chevrolet Camaro IROC-Z
Engine: 350 Tuned-Port Injection
Transmission: 700 R4
Axle/Gears: 3:73
I had the same proem on my 84 Z28 with drag radials. Try the wheel spacers, they gave me that extra 1/4 inch that i needed
Old Oct 12, 2009 | 08:06 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
spacers will make his problem worse
Old Oct 13, 2009 | 12:02 PM
chase1900's Avatar
Car: 1992 Camaro RS
Engine: L03 305 TBI
does anyone think dragbags or coil spacers/ shims will help any.. i really dont want to buy new rims.. i know i should have gone with more backspacing but its too late for that now unless some one wants to buy the rims for 150 a piece.. they have like 5 miles on them haha
Old Oct 13, 2009 | 03:46 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
they wouold both help, the drag bags would be better, but they are both still bandaids. New IROC springs for the rear are not that expensive and will most likely solve this issue
http://www.spohn.net/shop/1982-1992-...ings-Pair.html
they usually make the rear sit at least an inch higher
Old Feb 14, 2011 | 07:52 PM
cel19's Avatar
Car: 1987 Camaro S.C
Engine: 355 ci
What about the tire size itself? i just purchased cragar rims 15x8 with 3.75 B.S and the tire saize is only 215 65r i think, will i have these fittin issues also?? even with smaller tires???
Old Feb 14, 2011 | 08:10 PM
cel19's Avatar
Engine: 355 ci
Actually, My tire size is 255/60R15. Rims are 15 x 8 Backspacing 3.750 in. -19.00mm Offset. Will I have fitting issues with these or am I ok to roll with it? They have not been mounted just yet so I can send them back if need be.
Old Feb 14, 2011 | 08:15 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
you should have 4.5" of bs. those will stick out and you can run on the quarters if the car is low enough, or over bumps. that offset if for earlier f-body cars, 1st and 2nd gens
Old Feb 14, 2011 | 08:24 PM
cel19's Avatar
Engine: 355 ci
Can i get a recommendation of what rims to run?
Old Feb 14, 2011 | 08:35 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
rims are up to you, i just told you the specs you need
Old Feb 14, 2011 | 08:41 PM
cel19's Avatar
Engine: 355 ci
what offset?? 0?
Old Feb 14, 2011 | 08:57 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
if its a 15x8, you need 4.5" of backspacing, or a zero offset. If the wheel is wider, the offset wont be zero. you could get away with a little more on the rear to tuck the wheel more. The factory 16x8's have a little over 5" of backspacing in the rear.
Old Feb 14, 2011 | 09:02 PM
cel19's Avatar
Engine: 355 ci
OK so i read that the factory offset for the 82-92 thirdgen was a 0 offset, in order to prevent stress on bearins and handling problems, i would nee to stick at 0 or as close to 0 as poissible and a -19 woulnt work. correct?
Old Feb 14, 2011 | 09:28 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
the factory 15x7's i believe were all zero offset. the 16x8's had a zero offset in the front and a -16 in the rear. The rears will not fit on the front, they will hit the tie rods with a wheel smaller that 18", so a -19 will not work on the front at all. they should work on the rear.
it would be easier to just get zero offset wheels, 15x8, if heats the size you are looking for, on all 4 corners. that way you can rotate wheels and tires when needed.
Old Feb 15, 2011 | 05:43 PM
chase1900's Avatar
Car: 1992 Camaro RS
Engine: L03 305 TBI
haha this is such an old post but i ended up just stickin drag bags in the rear springs and it works great. 90 bucks and easy install.
Attached Thumbnails need help with tire rub...-image06112010143556.jpg   need help with tire rub...-image06132010232935.jpg   need help with tire rub...-image06112010143541.jpg
Old Feb 15, 2011 | 06:55 PM
Stephen's Avatar
Car: 87 GTA
Apparently your rubbing was just the tread hitting the bottoms of the fenders lips which means 2 things....Tires too tall or springs/shocks too soft. In those cases, drag bags are "cheap" band aides to stop the rubbing. I wouldn't exactly call $90 cheap though.
Old Feb 15, 2011 | 08:03 PM
chase1900's Avatar
Car: 1992 Camaro RS
Engine: L03 305 TBI
yea i guess not exactly cheep but better than loosing 200 or more, selling the tires and another 200-400 stuck with it buyin new tires and rims
Old Feb 15, 2011 | 09:39 PM
cel19's Avatar
Engine: 355 ci
Haha new post to me though, I just sent the new cragar trick 1 back in exchange for the factory spec cragar soft 8's, i acutally get 80.00 back in which ill just use to throw in for some new shocks and S*** any ways
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
mattcanty
Oct 12, 2015 11:08 AM
