Lubing Bolts - Greasing Bearings etc.
Car: 1992 Chevrolet Camaro RS
Engine: 305 T.B.I.
Axle/Gears: 2.73 Open Diff
What can I spray and with what to lube stay leaf springs, shocks, bolts, steering components, sway bars etc? I want to make sure everything is nice and sexy. What are the do's and don't?? I also want to make the pumpkin of my rear really shiny without much work how do I go about doing what? Should I spray frame with wd-40 or silicone or what?
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: Lubing Bolts - Greasing Bearings etc.
clean prep and paint the rear.
oil on sway bar?!? u only need to grease the bushings if your running poly. otherwise oil will do nothing.
WD40 is a cleaner by nature as well as a rust buster kinda. on joints like tierods etc u will need grease in the zerk fittings but depending u could spray wd40 if its squeeking alittle.
ambainb
Apr 25, 2016 09:21 PM
evilstuie
Apr 14, 2016 08:52 PM
red90IROCls1
Aug 25, 2015 06:56 AM
Dialed_In
Aug 20, 2015 01:45 PM
