Rear end help???
Old Oct 22, 2009 | 09:01 AM
dannyvera778's Avatar
Car: 91 camaro
Engine: LS3
Rear end help???
I had got in an accident which push my rear end a half inch right...i measured from the from to rear wheel on both sides and they are both even...is it possible that the bracket that holds the rear end moved?? if so is there anyway to fix that since it is welded to the frame??
Old Oct 22, 2009 | 09:36 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rear end help???
Check the pandhard/upper panhard for bending. Won't hurt to take a peek at the LCA's as well.
JamesC
Old Oct 22, 2009 | 10:05 AM
UMI Sales's Avatar
Hello
Yes it is possible that the mounting locations did get messed up! Has the vehicle been to a shop yet? If not I would highly suggest taking it to one and having it checked.
Hope that helps!
Brad
Old Oct 22, 2009 | 10:59 AM
Car: 91 camaro
Engine: LS3
panhard?? lcd?? sorry man need a lil help with that dont know the technical terms...and i had the accident a while back already had the body and everthing fixed and just put on a new rear end and this is what i encountered...my problem is also i already invested so much into this car body everything before the accident so im a lil stuck till i can figure the problem out
Old Oct 22, 2009 | 11:09 AM
JamesC's Avatar
panhard?? lcd?
The pandhard is the red bar above the jack (it's attached to both the body and axle and is responsible for keeping the axle centered). The LCA is the red bar just in front of the rotor. Both these pieces are after market, so they won't look like the OE, which is stamped steel.
https://www.thirdgen.org/forums/atta...s-89-drcar.jpg
https://www.thirdgen.org/forums/atta...89-lebrake.jpg
JamesC
Old Oct 22, 2009 | 11:17 AM
UMI Sales's Avatar
When you reinstalled the rear did you happen to lower the vehicle as well? If so that is normal and you will need to get a adjustable pan hard bar to recenter the rear back under the vehicle.
Hope that helps!
Brad
Old Oct 22, 2009 | 11:21 AM
Car: 91 camaro
Engine: LS3
no i did not lower it but i put a 4th gen rear end in...but i see the pan hard pics i know what they are had a brain fart...but i replaced all those parts with the parts from the 4th gen i will have to check to see if they were bent also which is possible cause of the 4th gen i had, had a lean to it they call it the 4th gen lean..frame tweeked...maybe that caused a lil bend in the panhard
Old Oct 22, 2009 | 11:29 AM
Car: 91 camaro
Engine: LS3
where can i get an ajustable pan hard that could fix my problem..
Old Oct 22, 2009 | 11:37 AM
JamesC's Avatar
UMI for one (Brad, any chance of a kickback here ):
http://www.umiperformance.com/catalo...4ddsnalqn2dch0
JamesC
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
