front lower control arms
Old Oct 21, 2009 | 12:25 PM
85SS/85GN's Avatar
hi
my brother has a 85 z28 that he is looking to rebuild. i was looking at it yesterday the drivers side tire is not center of the wheel well. and the other side is centered. what would cause the drivers side to be off like that? also is the control arm the same for all 3rd gens or different?
Old Oct 21, 2009 | 12:32 PM
ls six's Avatar
Re: front lower control arms
the arm is proabably bent from an impact, the arms are the same from 82-92 and are shared with many other GM cars and trucks.
Old Oct 21, 2009 | 12:48 PM
85SS/85GN's Avatar
if i change the arm and it still does not look right when what? i heared that g-body and s10 control arm are the same does anyone know if that is correct?
Old Oct 21, 2009 | 01:17 PM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
may also be alignment issue
Old Oct 21, 2009 | 09:03 PM
ls six's Avatar
It could be due to accident damage, both the frame could be bent or the fender could be displaced.
Check out the whole car for any wrinkling.
The G and T bodies use the same arm along with A bodies and a few others.
Old Oct 21, 2009 | 09:43 PM
Deimos140's Avatar
Car: 91
Engine: 427 with dual stage fogger
Transmission: TH400 with 2.75 1st
Axle/Gears: 4.11 moser 35 splines
I would say you are wrong being as G and A bodies using uppers and lowers and we only have lowers that and their spindle are different
Old Oct 22, 2009 | 08:32 AM
ls six's Avatar
Yes but the lower control arms are the same part. Never said anything about any other part of the suspension, but the rotors and calipers are the same depending on the year and option package.
3rd gen
S10
G body
Old Oct 22, 2009 | 08:43 AM
Deimos140's Avatar
Car: 91
looks like it would throw off caster to me. Eh whatever I would make sure the parts work o just get one since they are cheap as heck for our cars
Old Oct 22, 2009 | 09:40 AM
soultron's Avatar
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
Besides the bit for limiting steering they're swappable.
Old Oct 22, 2009 | 01:01 PM
ls six's Avatar
No they are identical, the alignment will be the same and the steering stop is the same.
Old Oct 22, 2009 | 03:12 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
the top pic and the bottom pic are the same side, the middle pic is the other side. is that why you think it'll change caster? cause in those pics, the one ball joint is located differently?
Old Oct 22, 2009 | 06:49 PM
85SS/85GN's Avatar
so are the control arms the same i have a extra set from a g-body if they are.
1992rs/ss
Jan 31, 2025 05:10 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
