front wheels uneven??? help...
Old Nov 14, 2009 | 04:20 PM
jjskibbs's Avatar
Car: '89 IROC
Engine: 350 TPI 5.7L
Axle/Gears: axle?? got me.. 3.73:1 gears
hey, i ahve an 89 iroc... i am redoing the struts/springs and noticed my left front wheel sits back towards the rear of the fender and almost hits it and the right wheel is a little farther foward than center. any idea what causes this? will new struts/mounts and alignemt correct this or is my frame maybe bent??
Old Nov 14, 2009 | 11:14 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: front wheels uneven??? help...
If it is that noticeable, probably not.
That's more likely... or it's your k-member or a suspension component.
Check your carfax
Old Nov 15, 2009 | 04:47 AM
jjskibbs's Avatar
Car: '89 IROC
yeah, it moved a little with the new struts and such, but barely... i'm thinking maybe a bent frame or k-member...
do you think this will affect the drivability of the car and if so, in what way(s)? i really would like to avoid k-member replacement if at all possible... $ is tight...
Old Nov 15, 2009 | 09:07 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Don't measure your wheel placement to a piece of sheetmetal that is hung next to it. Before assuming something is wrong check the measurement front to rear WHEEL.
If you don't have someone that can help, use a level to make a mark on the driveway exactly normal (perpendicular) to the center of each wheel. Measure between the marks. Make sure the car's driven a bit (50 or so feet is fine) if the front end has just been dropped off a jack to settle the struts.
If these marks are off take it to a shop to have it checked and confirmed. They shouldn't charge much for a quick inspection.
Old Nov 15, 2009 | 01:23 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
BTW the wheelbase should be 101".
If there is a noticeable problem, I say skip the driveway measurements and take it straight to a shop.
Old Nov 15, 2009 | 02:57 PM
92 Rally's Avatar
ye i would take it to a shop and have them check the alignment and inspect the frame
B_Dubya
Aug 26, 2015 05:09 PM
kah992
Aug 19, 2015 02:55 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
wruiz
Aug 11, 2015 02:59 PM
