Bumpsteer kit
Old Dec 3, 2009 | 05:40 PM
lonesomeloser's Avatar
Car: 1983 Z28
Bumpsteer kit
How low can a car be dropped before it would benefit from one? Or could it benefit at stock height?
Old Dec 3, 2009 | 05:44 PM
Stephen's Avatar
Car: 87 GTA
Re: Bumpsteer kit
Mine is dropped 1.75" up front & I don't feel the need for one, on good roads.
Old Dec 3, 2009 | 08:00 PM
1988-305-tbi's Avatar
Re: Bumpsteer kit
i think your ok untill about 2" stay away from the spohn bump kit, mine had way to much slop in it, and actually made the steering loose
Old Dec 5, 2009 | 03:21 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: Bumpsteer kit
Don't know how far until you "need" one, but I felt a huge difference in steering control after installing mine. Before I installed mine it was fine on smooth roads, but on anything with any bumps, it was an adventure. I have the Baer kit installed on mine.
Old Dec 5, 2009 | 04:25 PM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
Re: Bumpsteer kit
Good thinking. Talk about how you don't need a BUMPsteer kit because the car is fine on good roads. That's a classic.
Old Dec 5, 2009 | 05:00 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Bumpsteer kit
I recently put together a set for my car and it did make a difference. The alignment is still a little out though. Probably wont get that fixed until spring.
Old Dec 5, 2009 | 05:20 PM
Guest
Guest
Posts: n/a
Re: Bumpsteer kit
Ride height really has nothing to do with it.
The tierod swing has to match the arch of the A-arm swing. This can vary simply from an aggressive alignment on a factory ride height.
The more caster gain (stagnant and dynamic) the more the need to lower the outer tierod so that it marries the a-arm arch at mid articulation to allow for least change through travel.
Dean
Old Dec 5, 2009 | 05:25 PM
Guest
Guest
Posts: n/a
Re: Bumpsteer kit
The next question is, "well, how much does it need adjusted?"
Have any of you that installed this bump your car to find out? Or are you just putting this on there and hoping for the best?
You need to have the car bumped to find out, you may have gone for 1/8" in to 1/4" in----to---- 1/8in to 1/16 out for all any of you know unless you have gauged it.
Old Dec 5, 2009 | 05:38 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Bumpsteer kit
honestly, mine was "eyeballed". Took some measurements, and got a baseline, but i have to get everything setup properly later, probably in the spring when the car gets out again.
1Aauto
Sponsored Vendors
Feb 8, 2017 03:09 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:25 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
