SFC's or cage?
Old Dec 27, 2009 | 04:34 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Transmission: 700R4,700R4
Axle/Gears: LSD,LSD
SFC's or cage?
i was wondering if you put a cage in if you need SFC's...i was thinking not but just curious!
Old Dec 27, 2009 | 05:11 PM
chevy boi's Avatar
Car: 1989 i roc-z28
Engine: 350 tpi l98
Re: SFC's or cage?
if i rember right you get the subframe connectors on first and then you use the weld the roll cage to the sub frame connectors
Old Dec 27, 2009 | 08:56 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: SFC's or cage?
Unless you have a tube chassis, you need both. The cage protects the driver. Although it adds some rigidity to the car, it doesn't tie the front and rear subframe together like SFC do.
My car got SFC put in 10 years ago. I now have a full cage and still have the same SFC.
Old Dec 27, 2009 | 09:18 PM
ls six's Avatar
Re: SFC's or cage?
If it's a street car dont put a cage in it, it's nearly impossible to build a good cage that wont cave your head in in even a minor accident. They need to be used with a helmet and harness or not at all.
Hell I got a good bump on my head from a friends harness bar (about 1" dia thin guage tubing) when he accelerated to hard. This was in a FWD Mazda with 148 WHP as measured on a dyno that same day.
Old Dec 28, 2009 | 06:25 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: SFC's or cage?
I agree completely. Go SFCs. Then if you are just racing, do a cage. It is not safe to run a cage while not wearing a helmet. It gives too many solid places to smash your head against in an accident.
But yes, SFCs first, mount them as solid as possible (weld), then run the cage through the floor and weld to the SFC.
Old Dec 28, 2009 | 04:22 PM
BMR Sales's Avatar
Former Sponsor
Re: SFC's or cage?
Hello, i would agree. Go with the frame connectors first then get the cage installed. You can tie the cage into the connectors for added strength. We have two different styles of weld in connectors. Both are weld in units that reinforce the front lower control arm mounting point. Here is a link to our site. If you need any assistance please give me a call.
http://www.bmrfabrication.com/F3-chassis.htm
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
FueledSoul
Sep 30, 2015 09:18 PM
tmork454
Sep 29, 2015 06:33 PM
luvofjah
Sep 26, 2015 08:28 PM
luvofjah
Sep 10, 2015 10:41 AM
