problem new outer tie rod hiting inner tie rod
Old Feb 13, 2010 | 07:37 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
so I installed a new moog outer tie rod end and for some reson its alittle to long. I just need to clear one more thread turn and im home free but its already touching the inner tierod. so what im i to do. should i grind it down? would having it with 1 less thread turn really matter? before i took my old tie rod off i counted 6 threads and with the new one on i count 7.
Old Feb 13, 2010 | 07:43 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: problem new outer tie rod hiting inner tie rod
should have measured, they could be longer or shorter, the threads wouldn't matter then.
grind the end down a bit, there's usually a round bump on the end that you can flatten out without damaging the threads. Gat an alignment afterward anyway
Old Feb 15, 2010 | 06:35 PM
Car: 91 formula
but would it mess thinks up if it was one thread off?
Old Feb 15, 2010 | 07:34 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
the car wont explode or catch fire or anything, but it will affect the alignment a little, you toe in will be off. You may never even notice it.
take it for a drive, see what happens
Ghettobird52
Apr 21, 2020 08:44 PM
dyeager535
Aug 28, 2015 08:10 AM
zayne0
Aug 24, 2015 07:22 PM
theurge
Aug 21, 2015 12:46 PM
