steering box removal?
Old Feb 14, 2010 | 06:33 PM
sparkplug619's Avatar
Car: 1990 RS Camaro
Engine: 305 TBI
Transmission: T-5 stick
i am in the process of removing the steering box. I have everything off and the steering box is free, the only thing still connected is the pit arm, i tried unbolting it from the suspension but wont even budge, so i tried unbolting it from the box but still wont budge, is there a special way to remove it or do i need to use more force?
Old Feb 14, 2010 | 06:39 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: steering box removal?
on bolt the connection to the centerlink, its a ball joint, so its a wedge fit connection. You need a separator,pickle fork, and beat it in between the ball and the pitman arm. Or, screw the nut back onto the ball joint so that its loose, and just a tad higher than the threads, give it a could hard whacks with a 2lb hammer, and it should break loose.
Old Feb 14, 2010 | 06:59 PM
Car: 1990 RS Camaro
Engine: 305 TBI
Thanks alot, I bought a puller from autozone but was using it wrong... I got the puller between the ball and arm and used the bolt to pop it off!
Amillionoh7
May 24, 2020 08:01 AM
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
zayne0
Aug 24, 2015 07:22 PM
3rdgenparts
Aug 8, 2015 07:09 PM
