BMR STB Rubbing on hood...
Old Feb 28, 2010 | 02:58 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
After a 100 miles or so since fitting this, it appears the top of the center plate of the strut tower brace is rubbing the hood. Not very hard but it's rubbing.
Anyone suggest the best way of sorting this out? Anyone with similar stories?
Old Feb 28, 2010 | 02:19 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: BMR STB Rubbing on hood...
do you have poly motor mounts?
only way to really fix it is to find where in the hood its rubbing and grind it a little for clearance
Old Feb 28, 2010 | 02:35 PM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Thanks for the response. No poly motor mounts.
Is grinding the hood really the best solution?
Old Feb 28, 2010 | 03:23 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
how else would you do it? you cant lower the mounts for the STB, you cant lower the center section of the stb, and you cant raise the hood. So you either grind the powdercoated STB down for clearance, or you grind away at the ribbing under the hood where its rubbing. Or smash the center of the STB with a huge hammer until it bends and makes the needed clearance, but thats just a stupid idea.
Old Mar 1, 2010 | 02:11 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Cool- thank 86
Old Mar 1, 2010 | 04:31 PM
BMR Sales's Avatar
Former Sponsor
Can you take a closeup ic of were you mounted the bar on the strut towers? If its too far forward it will rub the hood alittle.
Old Mar 1, 2010 | 06:48 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
What do the motor mounts have to do with the STB and the hood clearance?
Old Mar 1, 2010 | 06:57 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
nothing, nothing at all, just a brain fart
Old Mar 2, 2010 | 04:51 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Will do, thanks for posting.
I did wonder about the tranny mount but just went with it
Old Mar 6, 2010 | 05:18 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
As promised-
Old Mar 22, 2010 | 05:24 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Please can anyone advise?
Old Mar 22, 2010 | 10:15 AM
brutalform's Avatar
I would say, judging from your pics, the bar should be back a tad. I believe the bar being that much forward, and the downward slope of your hood, is the problem.
Looks kind of close to the master cylinder though.
Old Mar 23, 2010 | 04:26 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Thanks Brutal. Think the Master Cyl just looks closer due to the picture.
Old Jun 13, 2010 | 12:17 AM
Dark Ember's Avatar
Car: 90' Firebird Formula 350
I have the same brace in my bird and its doing the same thing. I never cared enough to mess with it, but if I was set on correcting it, then I would take a rag or towel and drape it over the BMR logo, get a big hammer.....
Its crude, and probably dangerous since you could miss and nail the intake, but its only gotta bend down a little bit. If you wanna play it safe, remove it, get a jack or a press, and bend it just a little.
I know its Crude, but, its an idea.
Old Jun 13, 2010 | 04:55 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
fabrication that'll work shouldn't have to hit it too hard to move it alittle
Old Jun 13, 2010 | 07:16 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Reinstall the hood insulation and that should prevent the metal to metal contact. My problem was I had to shim the mounting points to clear the top of the intake and yes it hit my insulation on the hood. But there is more clearance on a Camaro.
ZZ3Astro
Aug 13, 2019 12:57 AM
MrPackstin
Oct 25, 2017 08:09 PM
meeklay812
Oct 1, 2015 03:46 PM
luvofjah
Sep 10, 2015 10:41 AM
buckshot63
Sep 10, 2015 09:15 AM
