manual steering box?
Old Mar 5, 2010 | 08:20 PM
tenholewheels's Avatar
was there ever a manual steering box for our cars fom the factory?
the yahoo that changed the drivetrain on my 83 z28 before i got it
more like rescued it from the hell it was enduring, left off all the
bracketry for the power steering pump.
all he did was slip a bolt that was for the water pump so that the
pump wouldn't drag the ground.
and after some research on the engine i have determined that the
heads don't have the required bolt holes for me to bolt the power
steering pump bracket to the engine.
so if there was a manual box i could get myself out this without a lot
of trouble, like changing the head or some high dollar aftermarket
serpentine system.
Old Mar 6, 2010 | 03:01 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: manual steering box?
No manual steering box for third gens from the factory.
A manual steering box from a 1st gen. S-series truck is almost a direct bolt-in. The only thing you need to do for it to fit is to grind the rear of the DS swaybar mount a little bit.
They can be found in 4 cylinder trucks. Make sure you get one with a 4-bolt top cover.
1992 Trans Am
May 10, 2023 07:19 PM
Amillionoh7
May 24, 2020 08:01 AM
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
zayne0
Aug 24, 2015 07:22 PM
