CE adjustable drag shocks
Old Sep 9, 2000 | 05:51 PM
ede's Avatar
ede
i'm about to install a set of CE adjustable shocks, what would be a good setting for them, on a drag only car? i'm running air bags too. would it be best to set up both shocks the same or not? thanks
Old Sep 9, 2000 | 11:15 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Start with a 50/50 setting. This will work best with a moderate track. If the track is very good and the tires are getting a good bite then change them to 70/30
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
Old Sep 10, 2000 | 10:21 AM
SteveSpohn's Avatar
Since you're running air bags I would set both shocks the same and use the air bag pressure to make fine tuning adjustments.
Set them on 50/50
Steve
Spohn Performance, Inc. - F-Body Suspension Specialists
Old Sep 11, 2000 | 09:12 AM
spud's Avatar
Car: 82 & 91 Firebird
Engine: 400 & 355
Transmission: TH350 & 700
Axle/Gears: 4:11 & 2.72
My CE shocks are set at the 50/50 setting and I haven't had any wheel hop, on the street or the track.
82 Firebird,355,Cam 224/234, .466/.488,TH350 Tranny,650 HolleyDP,Hooker Headers(I.E. POS) Manual steering,Lakewood LCA's,15X9 Centerline Warriors 275 50R15's BFG Drag Radials
Best 8th et 8.81@80mph.
Pac J
May 17, 2020 10:44 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
92projectcamaro
Dec 8, 2015 12:25 AM
loud91rs
Oct 5, 2015 10:05 PM
JSDaddy189
Sep 26, 2015 03:50 PM
