att. brake guru's(disc brake noise)
Old Sep 11, 2000 | 09:11 PM
NEKOMA's Avatar
i have a problem i cant solve with my front discs on my daily driver(98 chevy suburban 4wd), i have a annoying squealing noise that starts after the brakes are warmed up(sounds like when pads are junk and the squaler rubs)
and the sound only stops if i apply the brakes or turn the wheel hard, have tried 3 different kinds of pads and now have perf. frictions, i have also turned the rotors. tomorrow i am checking the backing plates and putting some of the silicon stuff on the backs of the pads(gm mech. suggested it) if this doesnt work i am going to have a sh** fit.
so if anyone can think of anything else i should check or try, PLEASE, PLEASE post a reply
thanks in advance
NEKOMA
Old Sep 11, 2000 | 09:48 PM
Tom Keliher's Avatar
Shims might due the trick. They install behind the pads. They are designed to eliminate brake noise, however I believe it is with the brakes applied.
It might be that your caliper piston is not retracting fully, or the caliper is not sliding on the pins properly. Might need to disassemble and clean and lube the pins.
FORMULA 350 TK
Southern California 3rd Generation F-Body OrganizationŠ
dbrochard
Oct 3, 2015 12:43 PM
GouldyGTR
Sep 7, 2015 09:05 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
