Can I cut my rear coil springs
Old Sep 12, 2000 | 05:34 PM
RussMan's Avatar
What are the consequences if I cut a coil out of my rear coil springs to lower the ride height? Is doing so a really bad idea? Plannig a rearend swap this week.
Old Sep 12, 2000 | 11:54 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It changes the spring rate. When you buy lowering springs they are the same springs but wound differently. Aftermarket springs will lower the car and keep the same spring rate. There's nothing really wrong with cutting springs. Do it with a cutoff wheel, not a torch, and cut 1/2 a coil at a time. A typical drop is 1 full coil cut off. If you cut too much, you'll need to get new springs.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
Old Sep 16, 2000 | 12:22 AM
fredo92's Avatar
Car: 92 Camaro RS
Yeah, you can cut the springs front and rear and it still aligns perfect. I purchased some Eibach 1" lowering springs for my convertible and I installed them and it still sat too high. I proceeded to cut a full coil out of the rears and a half out of the fronts. Since the rear springs are tapered, you must cut only from the top so they'll still sit in the pocket right at the bottom. On the fronts, cut off from the bottom so that the tops will remain flat (at least on eibachs you must do that.) Stock front springs can probably be cut top and bottom. So lets say that you want to cut a full coil out of the front, you take a half out of the bottom, and a half out of the top. Good luck with it man, and cut in small incriments, before you know it, you'll be sitting on the ground if you're not careful.
Old Sep 16, 2000 | 06:28 PM
RussMan's Avatar
Thanks for the input, man. I cut the springs on my Monte Carlo several years ago, but wanted to get some f-body owner input before I went to whacking. I subsequently bought some Eibach 1" lowerring springs for my m/c too. Haven't yet, but probably will cut those, too
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
TheExaminer
Aug 25, 2015 07:34 PM
TA8487
Aug 11, 2015 09:02 PM
