Alum?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Alum?
most of the ones you can buy off the shelf flex too much because they are rather small in diameter. You could use a larger, 1.25+ diameter bar, but at that point its starting to weigh more than a steel/chromoly one.
i would pass on aluminum for that
Guest
Posts: n/a
Re: Alum?
Yep, Chromemoly arms are stronger and lighter.
