Getting clicking noise on sharp turns.........
Old Sep 24, 2000 | 01:08 PM
IROC-ZTWENTYGR8
Guest
Posts: n/a
Sometimes when I make a sharp turn I get a clicking noise from the front end. Any ideas?? Thanks!!
Looking for:
87 IROC-Z L98
84 TRANS AM H.O.
Old Sep 24, 2000 | 09:42 PM
ProblemChild's Avatar
Check your "k" member to body bolts. If I remember right, there are 3 18mm attaching bolts, and 3 15mm brace bolts per side. If thats not it then you might have a wheel bearing problem, maybe loose, maybe trashed. The only other thing i can think of would be outer pads that didn't have the tangs hammered down, but that usually doesn't show up when the wheels are turned. Hope this helps.
Torque is KING!
All pray to the god of grunt! When ye thinkth ye has been whupped than shall ye meet the mighty Buick! For none can surpass her majestic power, and all will yet try. All pray to the god of grunt. For the King of torque has arrived!
1. 82 Camaro+ 1. 455" Buick+ 1. N2O plate = YOUR WORST FRIGGIN NIGHTMARE!!!
Da Problem Child
ProbChldR@aol.com
RS Reaper
Oct 17, 2018 07:52 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
Linson
Oct 1, 2015 09:50 PM
sjorgens
Oct 1, 2015 07:54 PM
