Power window regulator installation
Old Oct 9, 2000 | 04:59 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I had to replace the passenger side window regulator motor on my 92 camaro. Here is my problem: I cannot find the right sized rivet adaptor needed to install the rivets. I had to purchase the rivets from a dealership (6mm) and the largest size my rivet tool allows is 5mm. Its darn near impossible to mount the regulator to the door frame with nuts and bolts and I have not been able to find a 6mm rivet adapter. Any suggestions on how to put it back together?
Old Oct 9, 2000 | 06:47 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
You will have to get a different (larger) rivet gun that the auto workers use that will accept the larger rivets. You may be able to rent one (not from an auto parts store, but an equipment rental place) or buy one from an industrial tool supplier.
I replaced my drivers regulator (manual crank though) and I used nuts and bolts that was specified in the Chilton's manual. Like you, I didn't have the right rivet gun at the time and it needed to go on right away.
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60' on "Road Hugger" radials and dead Auburn posi.
Old Oct 9, 2000 | 07:41 PM
Pukka's Avatar
Thanks for the tip...my next move will probably be to a tool rental shop unless I can buy one for a good price.
BTW...I spent almost 7 years on Oki...stationed at Ft Buckner and Torii Station. Real small world!!
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
stalkier
Aug 13, 2015 12:59 PM
