subframe around steering box broken, any fixes?
Old Oct 3, 2000 | 11:02 AM
mike88RS's Avatar
where the bottom forward bolt of my gear box bolts through, the subframe has decided to fail about a 2inch round all around the bolt. the metal is just flexing around when the steering wheel is turned. is there anyway to weld metal, or any other method? or is my z28 ready to wreck?
thanks
mike
Old Oct 3, 2000 | 12:02 PM
ERIC'86IROC's Avatar
Find an experienced welder and he/she should be able to repair it. I would add a new plate to make it stronger than original. Even if he doesn't though, just a good weld is usually stronger than the surrounding material when the appropriate filler is used.
Anything can be fixed. At the absolute worst a piece of that subframe or the whole thing can be replaced with a donor from the junk yard.
350 Vortec, forged flat-tops, CompCams XE268, Edlebrock RPM, Holley 3310, TH350 w/Holeshot 2400, 3.23 posi, Heddman shorties, HEI
Old Oct 3, 2000 | 02:10 PM
Pino91Formula's Avatar
same thing happened to my 83 TA . I had it welded , you might want to check the radiator supports, where they were tack welded they all snapped from the frame flexing.
Old Oct 4, 2000 | 07:57 AM
ausrs's Avatar
dont feel to bad about the subframe cracking around the steering box
years ago i worked in a place that fixed mercedes ..was a common problem with them as well seems the more camber you run the more common it is to crack
Old Oct 15, 2000 | 08:14 AM
88IROCs's Avatar
<a href="http://www.globalwest.net/camaro93.htm">Global West</a> makes a steering box support brace which eliminates flexing in this area. It is sold under p/n TS-14 for $46.95.
He who hesitates,... is lost!
Amillionoh7
May 24, 2020 08:01 AM
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
zayne0
Aug 24, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
