Wheel Wobble
Old Oct 17, 2000 | 08:35 PM
Yeller92's Avatar
Wheel Wobble
Can someone help me.. I was driving through town and the guy next to me said my back drivers side wheel was wobbling pretty bad, is this a warped wheel? or a bent axle ? how do i tell? thanks
Chaz
Old Oct 18, 2000 | 09:53 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
I had (still do) this problem, but mine isn't bad enough to worry about. The way I verified it was to put the rear end up on stands and put the car in gear (have someone helping you so they can hold brakes and do the gears while you're observing) and then watch your suspect wheel. Stop your car, swap your rear tires around and see if it does it still and/or goes to the other side. That way it's quick enough to eliminate the wheel. In my case, it's the axle "hub" that's a little messed up, but that's a little bit more work to fix... Hope this helps...
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
FormulasOnly
Sep 6, 2015 10:42 AM
