>, third-gen, camaro, chevy camaro, firebird, pontiac firebird, forum, discussion, bulletin board, aftermarket" />> - Third Generation F-Body Message Boards" />
The RS has a "dead" spot in the steering at mid-turn >>
Old Oct 18, 2000 | 10:30 AM
Macgyver's Avatar
When I take a sharp turn, I have alot of steering wheel play, IE: the steering wheel turns, but the wheels don't do anything. This is only during sharp, fast turns...
Is there something worng, or is this normal...
Shane McConnell
macgyver@nethirdgen.org [*]Owner of a 1991 Camaro RS, 305 5-speed.[*]Owner of a 1979 Camaro Z28, 350/350.[*]Webmaster of www.NEThirdgen.org
Old Oct 18, 2000 | 11:46 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
It's not really normal, but it just means that some parts are worn out. Could be any of these things: center link, idle arm, or tie rod ends (inner or outer). I replaced all of those parts on my IROC this spring and it -really- tightened up the steering and feedback I get from the tires. Replacing them is cake, although I had my local shop replace the idler arm when I had the control arm bushings and ball joints replaced.
Greg Westphal
'87 IROC 305TPI/A4
Old Oct 18, 2000 | 02:41 PM
merf23's Avatar
also check the "rag" joint. It is under the plastic cover on the steering column just before it reaches the stearing box. If there is any motion in this then replace it.
db057
Apr 28, 2019 07:45 AM
Veaceonee
Sep 29, 2016 08:15 PM
bubbaz28
Sep 18, 2015 02:09 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
punkmaster98
Sep 8, 2015 09:45 PM
