Front sway bar size
Old Oct 18, 2000 | 05:40 PM
Viking's Avatar
Car: / 89 IROC /
Front sway bar size
I'm buying front swar bar bushings for my 89 IROC 305 TPI Automatic. The catalog lists 3 different sway bar sizes and I have no idea which one is on my car, 30, 32 or 34 MM? Can anyone help? Thanks in advance.
89 IROC original owner, 3 amplifier 8 speaker Kenwood/Infinity sound system, 300,000 miles on original 305 TPI. Change your oil!!!
http://members.bellatlantic.net/~viking88/iroc.html
Old Oct 19, 2000 | 01:01 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I like the sig- change the oil!
Take a large open-ended adjustable wrench, tighten it down on the sway bar, and measure the gap with a ruler. That'll tell ya. Measure the sway bar in a few places to make sure of your measurement. You might have a 36mm front bar if you have the WS6 option code on your glovebox sticker (aka "Performance Suspension" badge on dashboard).
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Oct 20, 2000 | 10:52 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
If it turns out your car has 36 mm front sway bar the 34 mm bushings work fine, no modifications req'd. Also I recommend getting ones with grease fitings. Or you can take the route I did and modify the stock bushing retainers and bushings to make them greasable.
Old Oct 21, 2000 | 12:36 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
The stock swaybar on my 84 Z28 is 32mm or 1.260"!
-Auggie-
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
