what do ladder bars do...
Old Oct 21, 2000 | 04:54 PM
spitfire350's Avatar
hey everybody.
this may be a stupid question but what do ladder bars really do? My understanding is that they use your rearend rotation to push your tires into the ground. Also do they bolt in inplace of the LCA's? well thanx for the help
keep the stang's far behind u and the cops even farther
Old Oct 21, 2000 | 06:42 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Ladder bars are a drag race only type of suspension. Because of the design, when used on the street, the rear suspension is very stiff. When one wheel goes over a bump the design forces the other wheel to lift also. On a race track this isn't a problem but in a street car it becomes annoying. A better setup for a street car is 4-link.
The third gens already have part of a ladder bar system. The torque arm is actually a 4' long ladder bar but because of how the rest of the suspension is designed it's not a true ladder bar system. The other problems with ladder bars on a third gen is ground clearance. I'm not sure how low it gets with the comp engineering setup but a typical system will requires modifying the rear floor pan for clearance.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
LS6 Big Block buildup now in progress
Best results before the engine blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
