brake light will not go off
Old Oct 27, 2000 | 09:18 AM
ANSONS84's Avatar
after I installed a new master cylinder my brake light will not go off. I believe it is linked to the propertioning valve. How can I adjust the pv?
Old Oct 27, 2000 | 12:14 PM
Mike Harvey's Avatar
How's your brake fluid level? I don't habe an answer to your PV question but I have seen on a lot of cars that when the braked fluid gets really low then the E-brake light comes on as a warning to fill the brake fluid. I don't know if our 3rd gens are like that but my Festiva is, I wonder about my Firebird if it does that, who knows.
- Mike Harvey -
Old Oct 27, 2000 | 05:50 PM
'89Formula305TPI's Avatar
Have you bleeded the brake system with care, mine was flashing a brake light too when changed the pads to all four corners and I thought that I pumped the air outta system correctly, I felt no difference braking with little air in the system, but then I bleeded again all corners and the light went off.
'89 Formula 305 TPI T-5
Check out my car HERE!
Old Oct 30, 2000 | 06:26 AM
ede's Avatar
ede
there is a small piston, or valve inside the porpoting valve. i'd say it's stuck. try rebleeding all 4 brakes and tap it lightly with a hammer and see if it frees up.
-=ICON MOTORSPORTS=-
Old Oct 30, 2000 | 03:30 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Oh that f'ing brake light! I saw that too many times when I did my axle swap. Turned out I had a bad master cylinder that was sucking air back in. Either yours could be bad, or maybe there's still air in it. The m/c has a "quick-take-up" valve in it that's a major pain to get the air out of.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
